SOURCE: how to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Testimonial: "This solution was very helpful for me. It helped me to install win 7 on my Toshiba Satellite A205-S5880 laptop. "
SOURCE: blue screen, launch manager, and empowering acer with windows 7 os
how can i setup the lunch manager in windows 7
SOURCE: My Acer Webcam Is Gone Ever Since I Installed Windows 7!?
As with all laptops parts are sourced from different manufacturers. Laptops had to be certified for WIN 7. Some ACERs laptop models are, but if the model wasnt certified for the WIN 7 platform they would not have developed a driver for your model. After checking ACER did NOT certify this unit as Windows 7 Compatibile due to driver incompatibilities. You can either downgrade to Windows Vista.. which will require a full reformat of drive (WIN 7 doesnt just uninstall) and reinstall from fresh VISTA.. so be sure and save your data. Or you can determine who makes the webcam in teh notebook and see if the manufacturer has a direct driver..OR FINALLY.. you could load the Vista driver and then go into the webcam software you use and right click and say run in "Windows vista" or "Windows XP" compatible mode. Be sure and keep looking at ACER to see if they state your system can go to Win 7 at a later date as sometime manufacturers will make drivers available which could change its status.
SOURCE: I have a dell studio 1537 laptop and have had
Studio 1537 is one of the classic models from Dell and it definitely compatible with win 7.. This laptop can be used for high end gaming and visual effects.. Its a good one...
Testimonial: "Thank you very much for the info. Regards,Mike S."
SOURCE: Can not install window xp
i went from window xp to window 7 and now i want to remove window 7 and go back to window xp.how can i do that with not a disk?
