Question about Palm Tungsten E2 Handheld
Palm is locked up
Help. My Palm is sick.
It turns on. I get a Tungsten "welcome" screen.
It goes to time and date page then freezes. Won't respond at all.
Can't even turn it off. I've done repeated resets. Same scenario every time.
Doctor, is there any hope?I have a palm tungesten E2 and as I was using it to beam a note to my palm centro phone (which I've been able to do several times) but it has now locked up. After several attempts to reset it from a "fatal alert" it would power on, go do the date/time screen and then to the "tap target" but that was as far as it would go, it just kept going straight to the 'tap target" and I would go through the the process of tapping the target but it just kept doing it, it would go no further. Then the last couple of times after the reset it went to the date/time screen but has frozen up because when I tapped on the "done" it would not go to any other screen. It is a good one about 2 years old or maybe 3 but has worked beautifully until now. Never had any problems at all with it. I don't have the instructions for a hard set (which means I will have to reload all my info.
Any help would be greatly appreciated
Thanks, Lila Litter
  • 24 more comments
  • Anonymous Mar 11, 2014
    how repair my samsung gt-s3653 that debug high
    How do I plumb it in instead of using the condenser
    fault code e52
    I"m looking for a user manual
    could it be toc or pcb
    how do i disassemble the oven clock panel for repair? do I need to pull the oven out from the wall?
    ON THE PACKARD BELL EASYNOTE TS
    The engine seems unaffected when the #6 plug wire is removed from coil.
    how to remove injector plug on a cts 3.6
    make google my home page
    hp laserjet 4200 ghost images
    customer rating for Commercial Gas Fryer, Dean Brand
    I have a coin silver Waltham pocket watch, serial no. 1585733. What year was it manufactured & what is it's approximate worth?
    forgot the password to get into the system
    i need the ways to bypass
    I have changed the transmission oil in a Stiga PRO 110 ride-on lawn mower. But, I'm sure that I took out more than I replaced. How do I bleed the system? Theheader tank level has stopped going down.
    Were does the #1plug wire go on the distributer cap 350 chevy motor
    were is #1 plug
    always shift into overdrive. The spedometor jumps around a little bit. Changed out speed sensor seemed ok for awhile but problem came back. the problem will start in the first 20 miles from start up. play with it a little bit then goes away. will do fine rest of trip
    How do you record a new voice message on this machine
    What umber is it in the black box
  • Anonymous Mar 12, 2014
    the horn on my 2002 toyota camry will sound when turning
    wont spin with a load, spins fine empty
    canon ir 3025 density problem
    cant remove blown radio and clock fuse
    toyota tazz switching off while driving
    Sergeant:
  • 254 Answers
TRYING PUSHING A PIN INTO THE LITTLE HOLE IN THE BACK THIS WILL DO A HARD RESET IT MIGHT HELP YOU. --------------------------------- Anything that is pressing on the screen under the case bezel causes phantom screen taps that supercede any user input.
1. Remove screen protector.
2. Clean under the case bezel using the folded corner of a piece of copier paper as a scoop, going no more than 2-3mm under the case.
---------------------------- Resetting your handheld On rare occasions your handheld may not respond when you press a button or tap the screen. In this case, you need to reset your handheld. Doing a soft reset A soft reset tells your handheld to stop what it’s doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if needed. To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld. If your handheld does not respond after a soft reset, you need to do a hard reset.
Doing a hard reset Only do a hard reset if a soft reset doesn’t solve your problem, or if you want to clear all of your information from your handheld. A hard reset deletes all records and entries stored on your handheld, including the username that identifies the handheld. This is another reason why it's important to synchronize often, so you have an up-to-date backup available. Before you do a hard reset, be sure to synchronize. 1 Press and hold the power button.
2 While holding the power button, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld. 3 Wait for the Palm Powered™ logo to appear, and then release the power button.
4 When you see the message that warns you about erasing all of the info on your handheld, do one of the following: • Press Up on the 5-way navigator to finish the reset and show the touchscreen. • Press any other button to do a soft reset. Restoring your information after a hard reset If you synchronized before doing a hard reset, you can now put that information back on your handheld. However, you may need to re-enter some of your personal settings, as well as your color-coded categories in Calendar. 1 Open the Custom menu in the HotSync® application: a. Click the HotSync Manager icon in the taskbar in the lower-right corner of the screen. b. Click Custom. 2 Select the correct username from the list at the top of the box.
ALSO FURTHER YOU HAVE TO PERFORM BUT THAT IS MENTIONED IN THE LINK ABOVE JUST CLICK IT DIRECTLLY  http://www.palm.com/us/support/handbooks/tungstene2/en/maintain.pdf
PLEASE rate the solution if helped as this is the exact solution and information you required. thanks.
Posted on Mar 11, 2009
    President:
  • 987 Answers
  1. Hold down the power (on/off) button on your device.
    Note: Treo 600 smartphones have two power buttons. Hold down the one on the top of the unit next to the antenna.
  2. While holding down the power button, turn over your device so that you can see the back of it. Still holding the power button, use an unfolded paper clip or a similar small object, to gently press and release the RESET button on the back (Where's the reset hole?).
    • Treo 680: There is no RESET button; instead, remove the battery and replace it while holding the Power button. It helps to remove the battery cover (but not the battery) before starting a System Reset, so your hand is free to hold the Power button throughout.
  3. When the Palm Computing Platform or Palm Powered logo appears, release the power button. Depending on your device, this logo looks like:
    Note: On some devices, you may see a palmOne logo and a progress bar first. Do not release the power button until the second, circular Palm Powered logo appears.
    887_palmlogo_progressbar.gif Keep holding the power button during this screen. When you see this screen, you can release the power button.
    - or - 887_poweredcircle.gif Keep holding the power button during this screen. When you see this screen, you can release the power buttPalm is locked up - 887_centroscreens.gif>- or -
    887_centroscreens.gif Keep holding the power button during this screen. When you see this screen, you can release the power button.
  4. A message wPalm is locked up - 887_eraseall.gifng that you are about to erase all the data stored on your handheld.
    In response, do one of the following:
    • Press the UP button to complete the hard reset, erasing everything on your device
      or
    • Press LEFT or RIGHT to begin a soft reset, leaving your data intact.
  5. Your device wPalm is locked up - 887_touchscreen.gifhrough a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not delete the current date and time. It does restore other settings to the factory default.
  • Sibananda Mar 11, 2009
    3 Wait for the Palm Powered? logo to appear, and then release the power button.
    * Press Up on the 5-way navigator to finish the reset and show the touchscreen.
    * Press any other button to do a soft reset.
    Brigadier General:
  • 3,614 Answers
remove firs the battery for an hour, remove also the card.
  • micromaster
    micromaster Mar 11, 2009
    if the above solution was no success, DO reset the unit
    Sergeant:
  • 320 Answers
Remove the battery for sometime and try again after restarting it.
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
White Palm Centro freezes randomly. Doesn't respond to input
http://forums.palm.com/t5/Support-Downloads/Palm-Centro-ROM-Update-for-Freezing-Issue/td-p/165101
Mar 28, 2010 | AT&T Palm Centro Cell Phone - White
The screen just flashes palm powered. will not respond to anytype of reset or battery unplug.
I recently had some problems with my Palm. I went through the Palm online chat support which was free. You can do phone support but it will cost about $15. Here is a link to Palm support. If you scroll to the bottom of the page there is a link for the chat service. I have very good results. Best wishes. I hope this works for you.
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/supportservices/page_en.html
Aug 23, 2009 | Palm Tungsten E2 Handheld
Tungsten E2 just stopped while adding data said fatal error
Well had to do a hard reset- lost everything, had no back up, long story don't think I'll bother with palm ever again!
Apr 11, 2009 | Palm Tungsten T5 Handheld
Tungsten E2 has lit screen & not responding
You can take the back off and unplug the battery for a few mins, this sometimes will clear a logic lock
Feb 27, 2009 | Palm Tungsten E2 Handheld
After turning device on, not respond at all, after reseted.
Upon doing a hard reset, which I assume you did, try this
Palmpowerups.com
PowerDiGi
$18.00
Jan 05, 2009 | Palm Tungsten E2 Handheld
Problem with initial set up palm
When you turn your Palm on, on the main page there should be a list of icons. Make sure in the upper right-hand corner All displays with an arrow pointing down.
Then, click on the World Clock icon to change the date/time for your Palm.
Jan 03, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Palm is locked up
I would say if you have all of your information saved to the profile in Palm Desktop to do a Hard Reset.
Dec 15, 2007 | Palm Tungsten E2 Handheld
PDA intermitently powers up then freezes on "Palm Powered" screen
I had the same issue. What you need to do is to hold the power on/off button than press the reset button. The screen turns off (get black) than the will ask you to make a hard reset (which end up deleting all datas). The Palm will power on like the first time you turned it on after you bought it. Than depending which version you have it will possible ask you which language you will like to have as default. After selecting you neet to setup the rest. If this is done you sync it all data will come back :-)
Jul 04, 2007 | Palm Tungsten E Handheld
Palm Tungsten E2 Handheld Logo
50 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
