I need a repair kit for a apex gb43hd10 convergance problem
Repair kit to replace ic's and resistors
  • 3,459 Answers
Check the site www.TvRepairKits.com - they will not have your model listed but they can build a customer convergence kit for many models. You just need to send them a few photos of your boards.
Posted on Apr 19, 2013
  • 60 Answers
SOURCE: JVC 52" HD-52Z575 shows double images of people and words
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Posted on Aug 19, 2009
Slinteriors
  • 8617 Answers
SOURCE: Convergence parts? What are the specific pico fuses and resistors
There are six 3.15 amp picos use 3.5 amp when replacing and there are two 5 amp picos on the G board the resistors if needed are 4.7 ohm 1/2watt
Posted on Sep 07, 2009
SOURCE: AV-56WP30 Convergence Repair
I got the correct answer from another free service, I can't afford your paid service and listed below is the only answer that I received from you for free:
fxnlogo_s.png Technical Support, Instructions & Repair Service
Dear lmoore44052,
A new solution has been posted for your JVC AV-56WP30 56 in. Rear Projection Television problem on FixYa.com.
Click here to read the solution:
http://www.fixya.com/ThreadView.aspx?thid=3140051&prdid=186352
Regards,
The FixYa Team
Posted on Oct 09, 2009
SD Tech
  • 14553 Answers
SOURCE: I was told that my convergence ic's need to be
I can help---what level of skill do you have at soldering?
I know these sets pretty well--to begin with confirm actual model number to me---The IC's and resistors can be bought.
The question is are you able to solder etc if I step you thru it?
Whatever chips the set uses you can buy a pair on Ebay for under 15 dollars--the resistors can be purchased at any electronics or TV repair place.
I help people here even AFTER they give me a vote here--idea is for you to get your set fixed and save money.
Tell me exact model and how much skill you have and I will assist you---I do this here for free.
Regards, SD TECH
Posted on Oct 28, 2009
Testimonial: "very helpful and honest"
  • 2336 Answers
SOURCE: JVC AV56wp74 convergence. Resistor before ICs?
It's recommended to replace all the defective parts first because if you only replace the defective resistor, it might burnt again if the convergence IC is shorted internally. I would also suggest to measure the other low value resistors with multimeter.
Posted on Oct 30, 2009
Testimonial: "Thanks! I'll just replace everything. I was leaning on starting new anyway. Thanks for the fast response!"
Panasonic 51'' HDTV Model PT51HX42F - Turns off, light blinks 3 times, pauses, blinks 3 times again, etc.
the 3 blinks is caused by convergence failure indicating the Convergence ICs and resistors need replacement. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the ICs and resistors and also has the CD that shows how to do the repair.
Jul 28, 2012 | Panasonic PT-51HX42 51" Rear Projection...
AV-48WP30 - Is this a convergence board issue?
yes u r right that is the problem of convergence in your televisions.and it needs to be replaced to make it proper.
thanks.
Oct 29, 2008 | JVC AV-48WP30 48" Rear Projection...
Double faces with red 'halo' around people...after TV 'popped' and went off then back on.
Replace the convergence ICs and resistors. You can get the JVC repair kit called the AV48WP30 - AV65wp30 convergence repair kit from www.tvrepairworld.com which contains the ICs, Resistors, and the CD with repair instructions.
May 25, 2011 | JVC AV-56WP30 56" Rear Projection...
AV-56WP74 the convergence is off. blue is way out!
You will need to replace the Convergence ICs and resistors you can get the JVC repair kit called the AV48WP74-65WP74 convergence repair kit from www.tvrepairworld.com which contains the ICs , resistors and the CD with instructions,
Sep 23, 2010 | JVC AV-56WP74 56" Rear Projection...
Convergence amp
You usually have to replace the two ICs at the same time along with resistors to get the longest life from the Convergence amps. You can get the repair kit for your model at the following link which contains both ICs and all 6 resistors plus instructions with pictures that explain how to do the repair yourself. Heres a link to the correct kit for your model Toshiba.
http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
May 18, 2009 | Televison & Video
Apex 51' gb5108
Just click below for convergence repair kit;
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Apex Digital GB5108 51" Rear Projection...
Blue wave across screen
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
Aug 18, 2008 | JVC AV-56WP74 56" Rear Projection...
42H83 Convergence
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
Aug 10, 2008 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
