Question about Dryers
The drive belt in my Zanussi TD-183 tumble dryer is intact and correctly fitted, but the motor does not turn when the machine is started - there is just a humming buzzing sound. What might be the ca
There is a metal cylindrical component mounted close to the motor with wires running to the motor. Is this a solenoid for starting and reversing the motor and could failure of that part be the problem. If so how can I check that possibility and how can I get a replacement part. Alternatively, can it be possible that the motor is faulty, given the absence of any smell that I would expect from a burn out.
3 Suggested Answers
  • 82 Answers
SOURCE: Hotpoint VTD00 Tumble dryer. Motor runs ok without
The motor is bad and needs replaced. It could be the contacts or the bearings, either way you have to replace the motor.
Posted on Dec 13, 2009
  • 1218 Answers
SOURCE: Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Posted on Jan 07, 2010
Testimonial: "Jack was a great help. Really took the time to help me with my problem in depth. Thanks again."
How do i change drive belt on zanussi tumble dryer model number td 4112w
take back cover off ... place new belt bottom first then roll it round tub... WATCH YOUR FINGERS.....if no cover on rear undo two screws on lid (rear).....do as stated above but its harder.07779933829 uk
Feb 23, 2011 | Zanussi TD4100W Electric Dryer
Tumble dryer TD 4112 W has power but drum does not turn - light is on and it makes humming noise but won't start.
hello the first thing to check is. the long pin on the inside of the door these sometimes snap off . if ok then check to see if the belt has come or snaped if ok then you may need to check the capacitor this next to the motor will have 2 wires coming off it these dry up good luck
regards
shaun
Jan 17, 2010 | Zanussi TD4112W Electric Dryer
Zanussi TC470 Belt Tensioner
Do you have it fitted correctly to the idler pulley?
May 19, 2009 | Dryers
Zanussi tumble dryer. no.TC7114W
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
Aug 07, 2008 | Zanussi TC7114W Electric Dryer
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
