Question about Xerox CopyCentre C118 Copier
042-372 K Mode Sol Error Restart Printer Error 042-372
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: I have a Xerox Phaser
042-372 K Mode Sol Error Restart Printer Error 042-372 Restart Printer Each color has it's own solenoid. the K solenoid is the one for the black ink. It may be that toner has clogged the sensor on the inside right wall of the printer. Sensor hole is a small opening and K is the first hole. Clean it with a cotton swab and alcohol. clean any loose toner also. If this does not take care of it. The sensor board or the solenoid itself needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Jan 19, 2011
Error code E000002
That is the error code for a power supply failure or the printer not receiving enough power to heat the fusilier to print. This can be due to an power outage or not enough electricity flowing into the machine.
If the machine is receiving full power, you'll need to get rid this error through entering service mode.
1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
NOTE: from this point forward you'll be in service mode which has a 60 operational second window. After 60 seconds it will exit out of this mode and you'll have to start over.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
The printer should restart and be working normally.
Feb 21, 2016 | Office Equipment & Supplies
Epson B- 510 DN printer error printer restart 0x95 error
Epson Printer Error 0x95 occurs when the printer head has gone empty or you can say that it has become completely saturated. The reason for this Error may be issues in installation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Steps to Fix Error 0x97 in Epson Printer:
Solution 1: - Check Epson Printer Ink Head
Printer ink becomes dirty because the ink pad is full. Due to unbalanced ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
If this step is not working to fix Error Code 0x95, then go to next step.
Solution 2: - Manually Perform Steps with Epson Printer
  • Switch on your Epson printer.
  • "press+hold" together to stop ink power buttons.
  • Wait for sometime while the printer switches self OFF.
  • Switch ON again and your error should have gone.
Solution 3: - Run the System Under Safe Mode
You should try to run the computer under safe mode, and then you may receive a message from the system about your error existence is effectively solved or not.
Solution 4: - Uninstall Current Installed Software From System
  • On your Windows "Start" button, go to "Programs and Features".
  • In the "Control Panel", tap "Programs", and then tap "Programs and Features".
  • Choose that software program that you have just installed, and then tap on "Uninstall" button.
You can visit Epson Printer Support Number if you are still unable to resolve the Error.
Jan 24, 2014 | Office Equipment & Supplies
We have replaced the belt in oki c5950 printer and the warning light is still on and displaying Belt life error
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
May 10, 2011 | Office Equipment & Supplies
Error code 016-370 Restart printer If problem
Error code: 016-370
This is yet another error message asking you to restart the printer. You need to switch off the printer and then connect it via the USB cable. Press the hold and cancel buttons simultaneously. Then power on the printer again. On your LCD display you should typically see a message saying 'ready for download mode'. You will then need to initialize the firmware update process. LCD will change to the writing mode. 10 minutes later you will be prompted to start the printer again.
The firmware is available here:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R148843&SystemID=PRN_LSR_3100CN&servicetag=&os=WLH&osl=en&deviceid=6673&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=40&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=197745
May 02, 2011 | Dell 3100cn Laser Printer
I have a Xerox Phaser 6125 and keep getting message K-Sol error code 042-372 restart printer. Restarting printer does not correct the problem.
Thanks, Joe
Jan 19, 2011 | Xerox Phaser 6125 Laser Printer
Worked for the first time then stop working the second time.
BEFORE reinstalling try sol 1
>>reinstall the printer diriver with an updated version form vendor site
somtime the drive may have bugs with the os and new updates so please get an updated driver from the vendor website
sol 2 >>or try windows update for find on for you goto www.windowsupdate.com and see whether you have an driver update
sol 2 >>try restarting the spoller service this small this works on most printer with an corrupted spoller
Start, control panel ,admistrative tools, services, scroll down to
print spooler and do a right click select restart
for more information
http://support.microsoft.com/default.aspx?scid=kb;en-us;324757
please rate solution.. and remeber reinstall will solve the problem but you dont know what acctuall happend you nmay need to do the same thing again costing you big time
Apr 11, 2010 | Lexmark X4650 InkJet Printer
Error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 07, 2009 | Xerox Phaser 8500DN Printer
User gets the above error on the actual printer " error 09.038.46:43938 "
Solution:
  • Turn off the printer. Turn on the printer.
  • As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
  • Release the buttons, it will now come up in the service mode.
  • Scroll down to the function menu, hit ok, scroll to clear isc fault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Mar 12, 2009 | Xerox Phaser 8500N Printer
Error Message 016-370 restart computer
turn off the printer
1. Connect the printer through USB.
2. hold the enter button (the one in the middle of the circle) with the cancel button simultaneously
3. turn on the printer you will see the following message on the LCD screen
4. " download mode… ready"
5. Start the firmware update from the computer.
6. The LCD will change to "writing…"
7. After about 10 minutes it will prompt you to restart the printer.
Nov 27, 2007 | Dell 5100cn Laser Printer
Xerox CopyCentre C118 Copier Logo
2,156 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
