Question about Samsung CLX-3300 Multifunctional Laser Colour Printer SAMSUNG
Samsung clx-3300 paper jam needs extract how
Show if paper jamming how to extract
  • 92 Answers
SOURCE: Samsung CLX 2160 "paperjam2" problem
Hi ...
IN CLX 2160, paper jams usually occur in three areas of a printer. The following error messages indicate the area in which the jam has occurred:
  • Jam 0 indicates the paper failed to pass through the first sensor.
  • Jam 1 indicates the paper failed to pass through the second sensor and has jammed around the toner cartridge.
  • Jam 2 indicates the paper failed to pass through the second sensor and has jammed near the fuser.
Your error shows paper jam2 but i am giving you directions to fix the paper jams indicated by each error message so that you can handly any kind of paper jam issue with your printer.
Paper Jam 0 When your printer displays Jam 0, paper has failed to pass through the first sensor.
To remove the jammed paper, follow these steps:
  1. Power your printer off.
  2. Open the cover of your printer.
  3. Gently pull the paper toward you to remove it from the printer. Note: If you do not remove the paper slowly, you can damage the printer and the printer will require service.
  1. After removing the paper, make sure there is no additional paper in the paper path.
If your printer still displays Jam 0 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 1 When your printer displays Jam 1, the paper has failed to pass through the second sensor and has jammed around the toner cartridge.
If your printer still displays Jam 1 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 2 When your printer displays Jam 2, the paper has failed to pass through the second sensor and has jammed at the fuser.
If your printer still displays Jam 2 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Please vote if this helps ... Cheers :)
Posted on Jul 29, 2009
  • 3 Answers
SOURCE: Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
Posted on May 05, 2010
Testimonial: "Thankyou"
  • 553 Answers
SOURCE: I have a samsung CLX 3175 FW printer. Paper jams
The limit switches are just flags that block or unblock photo sensors. Try blowing the printer out with some canned air, paper dust on these sensors is a common cause of these problems.
Posted on Jun 23, 2010
Testimonial: "Thanks very much, I'll try that - I'd like to think it was as simple as that! Kind regards Ray"
SOURCE: CLX-2160N Paper Jam?
my printer Samsung CLX-2160 give me the message "paper jam", but I checked a lot of times inside and there is no paper. What's the real problem? How can I solve?
Posted on Sep 07, 2010
  • 670 Answers
SOURCE: Paper keeps jamming on Samsung CLX-3160 FN. How do
Paper jams are typically caused by the rubber rollers inability to put paper through the machine. Try cleaning the roller with damp rag to see if that improves performance. If the roller is badly worn, it will need to be replaced.
Posted on Oct 04, 2010
Testimonial: "This solution worked for me. Thanks for the worthwhle advice!!"
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
How do I remove a paper jam?
Dear
Pl. select correct media size in pc/printer as actual media. In general all samsung printers are recover from paper jam on opening and closing of the door. If your problem persists pl. up load a jam paper position photo.
Thanks and Happy new year 2015.
Jul 27, 2014 | Samsung color multifunct laser print...
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Aug 12, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Mar 04, 2009 | Samsung CLX-2160N All-In-One Printer
Keeps jamming
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3300 Multifunctional Laser Colour Printer SAMSUNG Logo
446 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
