Question about Gaggia Brera Coffee Maker
Brera not trun on - Gaggia Brera Coffee Maker
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Mar 05, 2016 | Gaggia Brera Coffee Maker
My Gaggia Brera has all four warning lights blinking simultaneously. And won't make any coffee. Ideas?
hi,when you have the warning lights blinking it may you have a faulty micro switches you have one for the brewer one for the door and one for the basket or faulty boiler not heating up
Oct 13, 2014 | Gaggia Brera Coffee Maker
Gaggia brera descale stays on
try to hold the steam/hotwater button for 5-6 seconds.
Aug 15, 2014 | Gaggia Brera Coffee Maker
Descale alarm wo'nt turn off after a full descale.
You have to reset this manually after descaling. This is done by pressing the bean selector button for 6 seconds.
Nov 10, 2013 | Gaggia Brera Coffee Maker
Giaggia Brera descaling problem
been talking to Gaggia (Philips) and they told me that with the newer Breras, you need to ill the water tank, put the machine into standby, then press the long and short cup buttons together for 6 seconds. This will start an auto descale programme (that they didn't mention in my manual!). A small amount of water will be dispensed through the coffee nozzles, then it will stop and the warning triangle and the prime warning light will come on. Place a large container under the panarello, then turn the knob to the right to dispense water. It will dispense about 50 - 100 mls (cold) water, then stop for about a minute. Just leave it and eventually it will empty the tank. Refill it and start again, but it will stop after a few seconds. Turn the knob back to central position, then it will dispense another small amount of water from the coffee nozzles, then stop with warning lights again. Turn the knob back right to dispense water, if it stops because of empty tank, just refill it. Eventually, the machine will stop and go to standby. Turn the knob back to the centre, refill tank yet again and the machine will start normally WITHOUT that descale warning light. HOORAY !!
Jan 22, 2013 | Coffee Makers & Espresso Machines
Gaggia brera brew group wont go back in
If you close the machine without the brew unit inside, the gears aren't aligned anymore. I tried to put the machine off and then back on. You can hear the gears turn. After a couple of repeats, I was able to put the brew unit back inside.
May 13, 2012 | Gaggia Brera Coffee Maker
Brera: coffee grounds inside + internal leak
finer grind setting and non oily beans did the trick for me.......
Apr 17, 2012 | Gaggia Brera Coffee Maker
Gaggia Brera Coffee Maker Logo
37 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
