Question about Reebok Exercise & Fitness
Re 11306 blows the fuse box when switching on treadmill
When i switch on my treadmill the fuse box blows the trip switch please can anyone help
  • 883 Answers
SOURCE: fridge is tripping fuse box
if this is a new problem that suddenly occurred, then trust the fuse box...the frig has a problem. Most likely a compressor motor that has been electrically damaged...could have been power surges from utility or lightening or unknown. It also could be a wiring problem in the house...mice have been known to chew through wire insulation...they feel the warm wires and are fooled into believing the wire is a live food source and start chewing. A test of this wire problem is to remove the frig and plug in something that will demand close to the same current...(should also contain a motor)...read the frig's label on back of unit.
Posted on Jul 29, 2007
  • 185 Answers
SOURCE: trip switch
is the dishwasher on its own circut breaker if so whats the size
Posted on Mar 28, 2008
jmeredith
  • 417 Answers
SOURCE: vaillant boiler - no power
hi,
try bypassing the thermostat on the wall by tying the red and green wires together behind the thermostat. Go to the maufacturers website and study there. Call a local furnace place and ask to talk to one of the mechanics.
Posted on Jul 10, 2008
SOURCE: LG WASHING MACHINE WM14225FD
My machine would not switch on this morning, no beeps or lights, I traced it to a small fuse on the main circuit board. you get to the board by disconecting from the mains, removing 2 crosshead screws at the back of the machine and lifting the top of the machine off ( once screws out, slide top of machine back about 1cm and then it just lifts off. You can now see the main circuit board, behind the control panel on front of machine. the fuse is hard to see and is solderd to the board on the lower left side, I solderd onto both ends of the fuseand replaced with a 10 amp HRC fuse, I still need to find the correct fuse rating, this worked for my machine.
However, and its a big however, If the 13amp fuse in youre plug blew and the trip on youre consumer unit, then I would imagine something big (pulling a large current) has gone down in youre machine to cause all these to blow, anyway hope this helps, Robin.
Posted on Dec 05, 2008
  • 83 Answers
SOURCE: Dryer trips the fuse box
I had this problem with our hoover tumble dryer, it might sound stupid but i changed the plug and it worked ever since, ours blew 5 fuses and tripped out the main fuse every time
hope this helps martin
Posted on Jan 24, 2009
This is a TS01 new fitness machine,recently I had to use the safety button and after that the screen is just blue now with no text etc, speed, heart rate nothing everything else works. Please can anyone...
replace the old batteries by new ones, clean the contacts batteries very well.
2) tight the ribbon cable inside, for keypads and clean it.
3) Adjust the REED switch, test for open or faulty clean it, and tight the connector very well, see the diagram attached.
See the block diagram
after you fix it , if the problem remain with the same problem , the display board is faulty.
Feb 08, 2013 | Exercise & Fitness
I have a rodgerblack gold treadmill ag-10302 when i switch it on at wall it trips the circut in my fuse box help please
1) please use a table lamp in connect in wall circuit. if the c.breaker trip again, the problem is your outlet wall. Call electrician or test the wires for touch each other or ground improperly, and fix it.
If the circuit is NOT trip, test the power cord for defective 2) test the main switch for shot circuit 3) test the c. breaker for defective 4) test the motor see the if the motor if short circuit see my personal TIPS for help motor , see the diagram attached. 5) test the output board, the board can be short circuit and replaced. Happy NEW YEAR God bless you
Dec 31, 2012 | Reebok Exercise & Fitness
Horizon 4000 treadmill is tripping mains circuit breaker and blowing plug fuse
see my personal TIPS and test the motor.
2) the main board can be faulty, replace
3) lube the machine for a DECK belt , the resistance can be another cause.
4) lube the roller bearing too.
5) test the power supply for faulty
see the block.
God bless you
Sep 19, 2012 | Exercise & Fitness
Why does treadmill keep blowing plug fuse as soon as you start to us it.
Dear Sir:
Hello, I hope everything is fine, in union with your family.
I will try to help you, inmediately.
INSTRUCTIONS: You must be carefully to do this.
    • 1
Cleanand routinely maintain the running belt. The belt may be worn if the treadmillstops operating or trips the circuit breaker or fuse. Look for any tears in the belt.Test the belt by putting the treadmill at full incline. If it does not shutoff, you may need to replace the belt. You can try lubricating it first, butthe safest fix is simply to replace it.
    • 2
Tightenthe running belt if it is loose. A belt can slip if there is too much friction.Be careful not to tighten the belt too much, though. You should be able to liftthe belt at least 3 inches.
    • 3
Pushthe belt in the direction that it normally turns. Turn off the power before youstart. If the belt is difficult to turn, there is high belt/deck friction.However, if the belt moves freely, that's not the problem.
    • 4
Examinethe roller sleeve to see if it is centered on the running belt. If not, this couldcause the belt to move to one side. Often a common problem with treadmills, youcan try making adjustments yourself, but eventually you may need to replace thesleeve or roller.
    • 5
Stopthe treadmill and immediately unplug the power cord from the outlet if younotice a burning smell. Overheating could be a sign that there is too muchfriction or a short in the wiring. Examine the belt and deck for any signs ofwearing. If they check out alright, inspect the wiring. Replace any damagedparts as needed.
    • 6
Checkto make sure that the power switch is on if you suddenly lose power. If thisisn't the cause of the power loss, unplug the treadmill from the wall outletand individually test the fuses, breakers and switches. Test the wall outletfirst, as a fuse may have blown or a circuit breaker tripped.
    • 7
Allowthe treadmill to run at a speed of 2.5 mph without anyone walking on it if younotice fluctuations in the speed. The speed should be constant. If not, therecould be a problem with the motor.
    • 8
Testthe motor using a fully charged lantern battery. The motor should still operateat slow speed.
    • 9
Replacethe batteries in the panel if it dims. If the batteries aren't the problem,check to see that all the wiring is still intact. Sometimes a wire pulls loose.
Thank you in advance, sincerely. God bless you.
If you need further assistance, please reach me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Oct 03, 2011 | Reebok Rt1000 Treadmill Walking Belt
Please can anyone help me I bought a 560hr treadmill today second hand it was workin perfectly, until my son and grandson went on it ..it now will turn on but the belt will not go it trips the power switch...
12_7_2011_9_56_59_pm.gifSee the block diagram that I did for you. Now you will see how many elements or component has the treadmills. If the fuse or breaker are trips. you must inspect and test: 1) Power cord some internal wires is touching insider and produce short-circuit. 2)Capacitor in short 3) Coil or transformer in short 4) Main Motor in short 5) Main Controller Board.
Finally see for any wire is loose and touch the chassis from the machine in that case produce a BIG SHORT. sincerely.
Good luck, G-d bless you.
E.CUADRA
Apr 03, 2011 | Proform 560hr Treadmill Walking Belt
I have a T700 treadmill and the breaker blowed. I got a another breaker but it also blowed. What can be making the breakers blow ?
Hello, what do you mean by the breaker is blowing? The one in the fuse box or the switch on the back of the treadmill?
Feb 06, 2011 | Horizon Exercise & Fitness
Treadmill electical issue: My Spirit SR275 Programmable treadmill blows the panel electrical fuse for our workout room when I start the belt. I can operate other treadmill control functions without blowing...
A treadmill has a high current draw -- it should be on a dedicated 15 amp-circuit -- if sharing a cricuit, it's not unusual, from time to time, for it to trip a breaker or blow a fuse in the main panel.
Charlie
Jan 12, 2011 | Kitchen Ranges
When the machine is switch on from the main socket and than on from the machine on /off switch, it trip the whole house fuse box.I have change the 13amp.plug fuse, I cannot locate where the machine...
hi..It is next to the switch where you turn on.Open the
casing that stores the motor etc.Should be able to locate
it there,usually hidden inside a capsule.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Exercise & Fitness
Blown fuse
Check your door switches or your turntable motor, these could also cause the fuse box to trip.
Mar 25, 2009 | Sharp Microwave Ovens
Tumble dryer will occasionally cause the trip switch to blow. we can not the put the power back on till we have switched dryeroff at socket
Hi, Thanks for the question The problem you are having is with the fuse box . Its common to have the contacts in the fuse box to corrode . and cause the fuse to over heat . and blow .So replace the fuse box for the dryer . Thanks the appliance doc
Sep 30, 2008 | Dryers
Exercise & Fitness Logo
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
