Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Paper jam We just bought the L7590 HP Printer last Feb. 4 but recently we always encountered a paper jam problem. What should we do and what maybe the cause of it. Thank you very much for your response.
  • HP Master
  • 419 Answers
A paper jam is when paper feeds badly (ie: skews, crumples, gets caught, etc...) in the printer mechanism and stops the flow of paper through the system.
The first thing you need to do is get rid of the paper that's jammed everything up... To do this you'll need to:
  • Open the printer lid (lift the lid by placing your fingers under the control panel lip and carefully lifting upwards)
  • Remove the rear panel (press the two grey buttons/tabs inwards to release the panel)
In each of the areas you expose you will probably find some paper which has started feeding and then stopped.
IMPORTANT: DO NOT Yank or otherwise pull the paper out in an abrupt fashion as this can and often does damage the printer feeding mechanism..
The best way to remove a jam is to try and pull the paper out in the same direction as it would normally feed ie: straight out.. Pulling to the side is not a good move... It takes a little bit of time but also look for ink soaked pieces of paper which may lie doggo and hidden as they will cause other problems in the future.
You may also want to get the printer to move the printhead over to the left side by pressing and holding the OK button (on the control panel) as if you were replacing the printheads and see if the printhead has ripped any paper off into the parking area (far right).
Once you've done all that and made sure there's no paper or bits you can replace the rear panel and close the lid and you should be good to go...
If the problem repeats, look for foreign objects where the paper bunches up and also make sure that your paper guide (the moveable part in the paper tray) has been moved into position to guide the paper properly (ie: not TIGHT against but not looser than a 1mm or so).
Hope that helps.
Martin
Posted on Mar 13, 2009
How to fix a false jammed paper on an hp officejet 7500 printer
How do you know it's false? a small piece of paper can still sit in one of jam sensors causing that.
Feb 27, 2012 | HP Officejet Pro L7590 All-in-One InkJet...
Carriage jam
There are a number of things that can cause a HP printer carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an HP expert technician to mend it.
Oct 05, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Magenta and cyan will not print on my hp officejet pro L7590 -- it started with a paper jam that was corrected - ever since then only the yellow and black will print on the paper -- printheads are good and...
Same thing happened to my printer hp L7590. Printed diagnostic, only black and yellow printed; diagnostic for printhead health Ky=good, MC= good. Only Hp products ever used. Uplugged, & discharged static, cleaned copper parts of printhead. Still no fix. On visual examination of floor of printhead compartment rectangular pad ( approx 1/4" by 1/2") is missing. I can only guess that during the paper jam, somehow the pad got caught up and went awol. Not sure what to do now.
May 26, 2010 | HP Office Equipment & Supplies
Says paper jammed but cleared out paper and still says "paper Jammed" and seems to be frozen now. Unplugged it and once back on still says paper jammed.
I think the printer is due for service, all you need do is to get a technician to help you service the printer.
Compliments wish you best of luck.
Dec 25, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
False Paper Jam
Unfortunately, I think that the sensors are beginning to fail, and that is the result of a faulty sensor. How old is the printer? If I was you I would call HP and talk to them.
Ryan Frame
Creative Energy Associates Technical Center
May 11, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Cleared paper jam &printer will not reset
I had to turn off the printer & disconnect the power cord. I also had some material that was backed up on hold from the night before that was preventing the current material from being printed & I had to go in & cancel the documents to be printed before the printer would function.
Jan 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Jammed prints
change the printer roller your problem will solve
Aug 04, 2008 | HP LaserJet 1150 Printer
HP 7210 - Carriage Jam
Your item jumped a knotch. Like the fan belt in a car, timing is off. Needs professional service. The carts are out of alignment.
Jun 02, 2008 | HP Officejet 7210 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
163 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
