Question about Silicon Power Touch 835 4GB USB 2.0 Flash Drive - Metalic Design, Blue
Silicon power JetFlash G4 4GB pen drive is write protected
My pendrive is write protected how can format my pendrive
My pen drive is write protected, unable to write or delete any file. Unable to format also. Transcend make 4 GB
1.Insert ur pendrive in port
2.goto run
3.type cmd
4.then go drive D:
5.type cacls pendrivepath: /p username:F
eg D:\>cacls I: /p Pawan:F
6.press Enter
7.then try to del or write file in pendrive
8.or email me on pspawan01@gmail.com for other solutions
Nov 11, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When file is copyied in pendrive ,file gets corrupted,so what can i do?
hi...
This is because the pen drive contiains viruses. scan the pen drive and computer with the proper antivirus.after scanning delete all the viruses from it.
Then if the viruses are not deleted from the pen drive please format the pen drive. you cn remove the viruses by formatting.
DONOT connect your pendrive with the computer having viruses in future or else again you wil get the same problem
Jul 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
Feb 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend JetFlash V60 16GB pen drive is write protected
Flash drives by default use the FAT32 file system. FAT32 has a limit of 4gb per file. So you could have four 4gb files on your pen drive, but no files bigger than about 4gb. You could use the NTFS format, but it's not suggested for flash drives since it reads/writes much more often than FAT and will make the drive lifetime MUCH shorter.
Aug 26, 2009 | Electronics - Others
V10, 8gb,transcend ,write protected
Hello sir,
If you want to format your pendrive and recover data..Transcend company provides there own software to make your pen drive perfect and working..you can get that on there website..or else here is the direct link http://www.transcendusa.com/products/online_recovery.asp
Aug 23, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Remove Write protection from the Pen drive permanently
Hi Abhishek,
There is a samll tab in the which will have lock mark, move it to unlock.
That will remove the write proterction, still have issue replace the drive.
Thanks
Smith
Jul 15, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Pendrive gets write protected
chk out status of your pen drive in disk management
Apr 03, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pen drive write protected problem
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your Pendrive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your pendrive.
Dec 06, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 8 GB Pendrive showing write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
Nov 07, 2008 | Transcend (589307) Media
Problem regarding the write protection of pendrive
sir,
i am not able to delete files from my pendrive nor am i able to format. every time i try to delete or format, a window pops up saying that ur pendrive is write protected
Sep 03, 2007 | Computers & Internet
Silicon Power Touch 835 4GB USB 2.0 Flash Drive - Metalic Design, Blue Logo
Top Silicon Power Cameras Experts
Are you a Silicon Power Camera Expert? Answer questions, earn points and help others
