Question about Dell Inspiron 1420 Laptop
My dell 1420 laptop does not startup unless I hold it in my hand and apply pressure to the cassing
It will also not restart for the same reason
    Master:
  • 663 Answers
There is something loose inside your computer. You just need to tighten the screw up. I think you need a technician or a techy friend to do that because there are a lot of computer parts that you would need to check.
David
Posted on Apr 18, 2013
3 Suggested Answers
SOURCE: formatting dell laptop 1420
When you want to perform reinstall using cd, enter into bios by tapping F2 hey when you power on your laptop. Go to boot sequence and change ON board or USB CDRom to be first. Insert the Vista DVD. Save the settings and exit. When your system restarts you will find a quick message "Press any key to boot from cd/dvd...." when you see this message press any one of the key on the keyboard immediately.
For screenshot of step by step installation please visit the following site:
Vista Installation
In case of any further help you can contact me @ support@computerhelp.co.in.
Posted on Feb 04, 2009
  • 987 Answers
SOURCE: DELL INSPIRON 1420 BCM2045 INSTALLATION DRIVER
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=555&l=en&s=biz&ServiceTag=&SystemID=INS_PNT_PM_1420&os=WLH&osl=en&catid=&impid=
from here download the bluetooth driver..
Posted on Aug 11, 2009
The scroll bars on my touch pad are not working on my inspiron 1420 laptop
that is already defective. you can not use anymore. not unless you replace it with new one.
Jun 29, 2010 | Dell Inspiron 1420 Notebook
Nvidia card on dell 1420 no image on screen on boot up
Restart the computer in Safe Mode with Networking by continuously pressing F8 at Dell logo. Go to the Nvidia website and download the latest drivers for your machine. If you are experiencing no video whatsoever, then either the screen needs to be replaced or a connection is loose or not working behind the screen.
Mar 20, 2010 | Dell Inspiron 1420 Laptop
HI i have dell inspiron 1420 and when it's booting machine is getting freeze if i press f2 to go to setup display is getting wiered colors and i can not go to setup menu or i tried to go to last known best...
click start....run....msconfig.
in the system configuration window select the startup tab on top right.
click disable all...click apply and ok
restart the system. this should fix the issue
Jan 29, 2010 | Dell Inspiron 1420 Laptop
The computer will not turm on even though the battery is fully charged and the AC power source is not broken
Remove the hard drive the ac battery,the cd rom and the memory.Press and hold the power button for twenty seconds.Replace the power and the memory try again to startup.
Good luck
Oct 25, 2009 | Dell Inspiron 1420 Laptop
Dell inspiron 1420 startup error
You need to cheat a little. First try to boot into safe mode by pressing the f8 key as soon as you hit the power (and keeping your fingers crossed on the other hand that it notices your doing this). Before you get too depressed just try booting into safe mode and then reboot normally. That may be all it take to fix it. Try this a few times before getting into the more serious fixes.
If you can get into safe mode you can simply copy your files off to a usb data drive. Those will still work. You may be able to use the wired network card if you select safe mode with network access. But don't count on that. The cd/dvd will not work so you can't burn it to disk. A flash drive will work on the usb while a external hard drive that connect via usb usually won't as it needs drivers.
The other way is to boot using a bootable cd. If you can get a vista install cd you can install over the top of your existing windows and retain your settings. If you don't know where everything is then you need to be a bit creative and use something like the demo Ubuntu cd that boots into a windows like operating system that will allow you to copy stuff over the network to the usb drive or the network.
If you have a friend with the right laptop or desktop you can take the drive out and set it up as a second drive. When they boot normally they then can see your drive and just copy burn or move your stuff. This is what I do in the shop when the existing system is too messed up to work with. There may be the odd thing you won't get access to but you should get most of it.
Jul 09, 2009 | Dell Inspiron 1420 Laptop
Dell Inspiron 1420 Factory Setting Recovery
back up all your files first because everything will be wiped out.
Turn on machine, Put the recovery cd on the cd rom drive, before it boots to windows hit the F1 to go into bios, on the startup set the cd rom the primary to boot machine on cd then follow the instructions from there..
Jun 30, 2009 | Dell Inspiron 1501 Notebook
Problem in os
Try starting explorer by going to file\new task (run..) and typing explorer.
If it doesnt work, just type msconfig on the same box and go to startup tab, leaving everything unmarked, just reboot your pc and problem should be solved
Jun 21, 2009 | Dell Inspiron 1420 Laptop
I have Dell inspiron 1420, but my laptop starts & shutdown very slowely
hmm that means there are lot of service is running in your computer...try this for starts-
1)open run command
2)type msconfig in run.
3) uncheck all unnecessary program at startup tab then restart system.
now for shutdown pc
try this
1) open run command
2)type regedit
3) search waitforkill registry using ctrl f.
4) increse value of waitforkill like 200 to 20000.
Mar 29, 2009 | IBM ThinkPad T30 2366 Notebook
Formatting dell laptop 1420
Hi, Most dells sold in the last 4 to 5 years are sold with a recovery partition on the hard drive. what this means is you should not need any disc`s to do a recovery, unless you have replaced the hard drive. A little trick that most people dont know is that you only need to hold down the CTRL and F11 for a few seconds. Remember you need to do it a s soon as the laptop powers up, you should be given a menu asking you if you want to do a repair or full recovery. if you choose full recovery the the laptop will be restored to factory settings.... hope this helps
Tony A
Dec 12, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1420 Laptop Logo
22 people viewed this question
Alun Cox
