Question about LG LDS4821ST Stainless Steel 24 in. Built-in Dishwasher
Lg Dishwasher model LDS4821ST OE error
Gives a OE error
SOURCE: oe code on LG dishwasher following garbage disposal replacement
Well, there is the plastic block in the garbage disposal where the drain hose goes on (as not every disposal will be attached to a dishwasher). Punch this out with a screwdriver, fish the plastic plug out with your hand and reattach the hose. You are good to go.
Posted on Dec 01, 2008
onthejob5130
  • 640 Answers
SOURCE: LG DISHWASHER TE ERROR CODE
you have 1 of 3 problems...the water is to hot over 140 degrees..your thermister went open,,or you have a bad pc board,,(control) onthejob
Posted on Feb 04, 2009
  • 3230 Answers
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
  • 3230 Answers
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
hi
Krazytech
  • 725 Answers
SOURCE: What does the error code OE mean on a LG
OE drain Error Not fully drained out in spite of 5 min. drain operation The Drain Hose kinked or blocked. Wiring connection is OK? The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled...
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit
Posted on Sep 27, 2009
LG dishwasher, it pumps out ok on start up in any program, but gives an OE error
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
Feb 12, 2016 | LG Dishwashers
OE error code on LG MODEL lds5040st DISHWASHER
drainage problem The pump impeller might be jammed or the drain hose is kinked or blocked or a bad pump Hope this helps
Dec 05, 2013 | LG Dishwashers
How to fix no power problem on LG Dishwasher LDS4821ST
LG lds4821 overheats filter board and burns it. Probably another part shorts and causes excessive current. Replacing the filter board makes dishwasher run but problem persists
Jan 25, 2012 | LG LDS4821ST Stainless Steel 24 in....
I have a code that says OE what is that
OE means the machine has sensed slow to drain condition.Check out website below,
Most likely food debri in drain hose.or air gap.
Disconnect drain hose from sink and blow a little compressed air into it to shake things up.Run a rinse and drain with hose disconnected into bucket to see whats going on.Trap on sink may be restricted as well.
Hope this helps
http://lgknowledgebase.com/rms/kb_frame/
Aug 18, 2011 | LG LDS4821ST Stainless Steel 24 in....
Just installed a brand new LG LDS4821St dishwasher. Washer will not drain. What do we do, no kink in hose
That's what factory warranty's are for, contact the place that you purchased it from or contact LG direct,
you paid for the warranty in the price of the dishwasher use it.
Good Luck !
Feb 21, 2010 | LG LDS4821ST Stainless Steel 24 in....
Error Code OE
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
OE Error
You do not have an "OE" error, it is actually a "DE" error. (Drain error) If after 5 minutes of drain time the pump motor RPM's haven't gone up the dishwasher knows that there is still water in the tub and throws the "DE" error. Often times the problem is the controller, but I have found more often that the problem is a long and/or restricted drain line. If someone had to extend the drain hose to reach a drain the extra resistance from the splice and pushing all the extra water in the long drain line prevents the dishwasher from pumping out within the time limit.
In some cases it is possible to correct this condition by first making sure the drain hose has a high loop to prevent siphoning, then running the drain line through the floor and into an open trap. (again, to prevent siphoning) Do not use extensions on the dishwasher drain hose supplied with the unit.
Oct 25, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDS4821ST Stainless Steel 24 in. Built-in Dishwasher Logo
49 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
