Question about Kenmore 700 6972 Dryer
Kenmore 700 6775 dryer no heat
The dryer is not heating at all. I bought it today (yesterday) from the one and only owner. It looks brand new. Im a girl with children. I don't know how to find out what is going on or fix it. I checked the door switch and the voltage converter in the wall, this dryer calls for a 220v mine is a 125/250v converter, would this cause the problem?
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Posted on Jan 02, 2009
tony2155
  • 64 Answers
SOURCE: Dryer runs fine but no heat
change the fuse in back of the dryer
Posted on Jun 23, 2009
aasc
  • 1606 Answers
SOURCE: Kenmore Model 110.96585200 No heat!
You probably have a bad thermal cut-off . This is the small thermostat , located at the top of the element housing . This " thermostat " should read infinate resistance ( no resistance ) . You can put the 2 wires togather , and see if heat comes on . pt # 3399848 . Both thermostats , should read 0 resistance . They are normally closed . The thermal cut-off , will not reset itself , if open . This is a safety t-stat , for when dryer gets too hot , and will have to be replaced .
Posted on Nov 11, 2009
Testimonial: "Great advice "
john631068
  • 172 Answers
SOURCE: How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Posted on Nov 17, 2009
Kitchenaid prestige dryer not heating
I worked on a similar dryer with the kenmore brand on halloween. nothing had been done to the dryer since it was new. Take a look:
Kenmore 4-wheel drive dryer de-mystified!
Feb 05, 2013 | KitchenAid Dryers
Hello! Yesterday we cleaned out our home dryer vents. Today the heat wil not come on in our kenmore elite dryer. It tumbles and blows cool air, just no heat. Suggestions? Thank you!
If you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 25, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Sears Kenmore Model 65862 that now does not heat. Worked yesterday but not today.
Looking for the two circuit breakers or fuses since this is a 220 dryer that would need two 110 inputs.
Jan 15, 2010 | Kenmore Dryers
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
The unit runs but no heat.
Your limit switch has tripped. You will find this small switch near the burner that is the size of a dime. Press the small button between the wires firmly to reset it.
Apr 16, 2009 | Dryers
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Apr 13, 2009 | Kenmore 62802 Electric Dryer
This is our 2nd new Maytag Performance Series 5000 gas dryer. Bought at Home Depot. Originally bought w/d and they just dumped the pair off. Had to hire a plumber to come and hook the gas up. Washer works...
No solution. In fact we just bought a new 5000 dryer and it did 4 loads before DYING. Will not dry at all and machine definitely is turned on. Currently struggling to get it replaced.
Apr 10, 2009 | Maytag MGDE500V Dryer
No heat
have you checked the heating elements? you say the tub turns, is there any air coming into the tub and if so is it cold? if it is then you may want to get the heating elements checked.
Feb 09, 2009 | Kenmore 63942 Dryer
Kenmore he3 not heating
REMOVE 2 SCREWS ON BOTTOM OF PANEL,, REMOVE LINT SCREEN , NOW REMOVE BLACK METAL HOUING ,,,DISCONNCT POWER BEHIND METAL HOUSING THERMAL FUSE IS RIGHT THERE REPL ,NOW SHOULD HEAT UP ,,,2 RED WIRES CONNECT TO IT
Nov 23, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 700 6972 Dryer Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
