Question about Ricoh Aficio CL3500N Laser Printer
How to enter service mode on nashua cl3500 - Ricoh Aficio CL3500N Laser Printer
Error code J020 on a Nashua Aficio MP C 2050
You must call Customer Care for the support. Entering the wrong way can permanently damage your printer. Just a call at +1(800) 243-0051 Toll Free
Apr 27, 2017 | The Office Equipment & Supplies
My copier nashua africio 1022 is showing error sc542 and cant work
1. Press the Clear Mode key. (yellow key)
2. Use the keypad to enter "107".
3. Hold down Clear/Stop for at least 5 seconds.
4. Enter Copy SP mode
5. Exit.
6 turn off machine then after 5 seconds on the machine.
if problem exist again replace thermistors then repeat the above simulation 1 to 6
Aug 19, 2011 | Ricoh Aficio 1035 Copier
I have a device NASHUA SERIES 1515MF, it no longer works, it displays the code sc542
this is a fuser code
try this:
1. Press the clear mode key (yellow key)
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON.
If this does not have to hook up with the technical assistance to replace the fuser roller and thermistors
Jan 23, 2011 | Office Equipment & Supplies
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
I have a Nashua Aficio 1013, it gives me a SC549 error report and it doesn't perform any of its fuctions. how can i solve this problem?
This is a fusing temp problem. Try the following to reset. function clear(yellow button) 107 hold down Clear button(red button)Machine will enter SP mode. Go to menu 7 (Data log) go to 807 ( SC/jam reset). Input 1 for yes. hold down the original type button (the button where you select Foto/text) then press #. Machine will reset and show action complete. Turn machine off and back on. If the problem is still there you will have to check the thermoster and might have to be replaced. But normaly this will do the trick.
Apr 26, 2010 | Ricoh Aficio 1013F Copier
ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Jan 14, 2010 | Ricoh Aficio 450 Copier
Does anyone have a User Manual for an old Nashua
Probably because the instructions were wrong - to set the clock you first have to press the big blue button "A" on the face for 2 secs, the use a pen to depress the silver recessed button "D" on left side to get past the 12/24 display, then depress the "D" button (not the "A" button as the instructions said) to set the clock.
To set pulse, press "A" two secs. Press it again to bypass recall mode. Now enter upper bound: pressing "D" constantly/intermittently as it falls to desired level. Press A to store. Now enter lower bound: press "D" again til it rises to correct level. If you overshoot it just comes round again.
I'm entering this here for when I lose my instruction sheet too!
The "B" button top right is the stopwatch/reset/start/stop - press to clear.
The "C" button lower right is the nitelite, and not recommended you use it more than 30 sec total/day.
Apr 23, 2009 | Exercise & Fitness
Ricoh Aficio CL3500N Laser Printer Logo
16 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
