Question about Samsung LN46B530P7FXZA LN46B530 46 LCD TV 16:9 ATSC
My samsung ln46b530p7fxza (46" lcd ) turns on an off clicking, pic is upside down. i replaced power supply cause of bad burn marks on board, but still doing it.
Tritronic
  • 5 Answers
SOURCE: picture is upside down Samsung HLR 4667W 46 inch
Enter service.....go to engine and change engine type. This work
Posted on Sep 06, 2008
  • 2336 Answers
SOURCE: Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to jah2mil@hotmail.com
Posted on Jan 05, 2009
SOURCE: Same "clicking" problem with 46" Samsung LCD...does not turn on.
With any luck you will have the same problem asa the rest of us : blown power board capaciters , remove the rear cover {20 screws} look in the middle of the back of the set with the cover {5 screws} removed from the power supply . Now look to the upper right cornerof the board in the middle of the tv there may be 1 or several capaciters leaking from the X shape on the top , this be be your problem match up replacements but source units that have a higher max voltage than 10volts 7 get them soldered into the board . I repaired mine that failed at 16 months for $4 in parts & it took longer to remove the screws than it did to affect the repair. If you are not conifident about soldering on your $2000 tv then take the board to someone for the job to be done , I would not advise this as a first soldering job , good luck I can't belive how common this is Samsung needs to step up ......
Posted on Sep 17, 2009
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
I have a Samsung 46 LN46C630K1F CCFL TV with a backlight that doesn't come on. How can I tell whether it is the inverter board or the power supply board that is bad?
Check and replace the damaged components at its back light inverter circuit. What else to look for? If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/ Sometimes the back light inverter board might need replacement.
Feb 20, 2017 | Samsung Televison & Video
I have a Samsung LN52A650A LCD TV that 3 years old. Today when I go to turn it on it just clicks and does not turn on. The clicking wont stop...it clicks about once per second. I have to unplug the TV to...
The tv power supply board have dead components parts call capacitors most likely.U have all the tools and understanding basic electronic also can do basic soldering too?The tv power supply board that the board where the power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and dead capacitors parts.These capacitors parts are alway bulges up or puffing up on to it tops.Must replaced all these dying capacitors parts are bulging up ur puffing up on to it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
May 11, 2011 | Samsung LN52A650A LCD TV
SAMSUNG 46 LCD SLOW TURNING ON CLICKS ON AND OFF SEVERIAL TIMES BE FORE COMMING ON SEVERAL MINUTES and geting slower ANY HELP PLEASE
It seems problem with power supply board as there are few electrolytic capacitors in output section that would be leaky/ dried up, replace them to solve your tv problem.
Please note, if you are handy with electronics stuff repair and an replace parts in circuit board then can attempt to do it yourself because it requires soldering work with proper tools OR call local tv repairman to do this job for you.
Check following image of power supply board of Samsung LN40A450, capacitors have been marked that needs to be replaced.
Hope these info will help you.
Thanks.
Nov 30, 2010 | Samsung LN40A450 LCD TV
When I turn on my Samsung LE46F86BDX LCD TV it click's for some time. After about 2 minutes the TV starts playing normal. Afterwards you can turn off the TV and back on again. The TV starts normal....
This problems very common on a LCD tv.It the tv power supply board,have bad dying capactors,these capacitors are alway bulges or puffing up on it tops.That the board,where the power a/c cord plug into it.U have all the tools,know basic electronic and can do basic soldering?Just check the power supply board,for those dying capacitors that bulges or puffing up on it tops.Replaced these dying capacitors on the tv power supply board,ur tv will power up normal again and have no more clicking sounds and will not take anymore 2 mins or more to turn it on.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 25, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
My samsung ln-t4671f takes 3 to 10 minutes to turn on. it just clicks,clicks clicks
The power supply board is dying,that the board where the power a/c cord into it.Replaced the power supply board will stable and work as normal again.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 03, 2010 | Samsung LN-T4671F 46 in. LCD Television
When I turn on the tv, it clicks on and off repeatedly for about 3 minutes before the picture actually comes on. What is causing this?
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com for the refurbish power supply board for the replacement.
Feb 27, 2010 | Samsung LNT4642H 46 in. LCD Television
LN 46 A 550 will not turn on. redlighr flashes and clicking noise heard
Power supply board it dead,buy a refurbish power supply board for replacement at Shopjimmy.com,Ebay.com.Know how to solder replaced capacitors that puff up or burst open,might get power back,because something else might burn,don't know about or the ability to find out.
Feb 03, 2010 | Samsung LN46A650 46 in. LCD HDTV
My samsung 46 LCD TV takes 5 - 6 tims to start?
Power supply board have dead capacitors.Know how to solders?Check these capacitors for puff up or burst open replaced these capacitors.Or buy and replaced the whole power supply board at Shopjimmy.com,Ebay.com.
Jan 27, 2010 | Akai LCT3201TD 32 in. LCD Television
When you turn 'on' the tv...the tv continuously 'clicks'
The clicking noise is caused by the relays on the power supply board trying to power up the system. Your TV has detected a problem that's causing the power supply to shutdown. Someone knowledgeable in electronics can track down the problem. The SOURCE of the problem could be another board other the power supply.
Mar 15, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
Samsung LN46B530P7FXZA LN46B530 46 LCD TV 16:9 ATSC Logo
125 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
