Question about Whirlpool Washing Machines
It shows up clean pump. But i cannot find where the pump is
  • Whirlpool Master
  • 3,361 Answers
Remove 3 screws across the bottom front panel to access the pump.
Unplug the machine first.
The pump will be in front of you then.
Posted on Mar 11, 2009
Whirlpool 6th sense washing machine manual
can you hear the pump
there may be something in the pump or in the pipes to and from the pump clean out
Dec 30, 2013 | Washing Machines
Clean pump
Remove the bottom panelb5a88d7.jpg or access the pump door if yours has one 39e0b0c.jpgand get that pump mess 5b68d36.jpgout is all.
May 29, 2010 | Whirlpool Washing Machines
Red lite showing by clean pump ,cleaned pump stil not working? only pump i found on google is one at bottom of washer wiv lik a fan inside , do i need a new one ?
Check the hose coming from tub to pump for obstructions. Then check all the hose from pump to drain for obstructions. I need the full model # to help further.
Mar 20, 2010 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Mar 09, 2010 | Whirlpool Washing Machines
I have philips whirlpool awo/d 4605 model and its showing a light clean pump where do i find the pump???
The unit front portion either right side or left side you will find the small door you just open the door and remove the filter in anticlockwise direction it will come out just clean the filter and then close it safely
If you want to clean the pump you are suppose to open the back door of the unit and trace the outlet valve it will be connected to the pump after finding the pump just remove the hose from bothe side of the pump and clean the drain pump neatly and refix it
Jan 05, 2010 | Whirlpool Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Fisherpaykel gwl15 washer will not pump down
remove as much water as possible lean washer back against wall ..pump twist locks into bottom of tub remove clamps with fingers pump will twist out no tools needed!!!! clean pump and retry
Sep 09, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
