Question about Apple MacBook Air
How do I view the photos in the memory card on my MacAir
Display contents of memory cart on laptop monitor
  • Apple Master
  • 739 Answers
2 ways.1. open the memory card and select the correct folder and the photos are in there. view with preview or quicklook (select the all then press the space bar) 2. open iPhoto, tell it to import picture off the card and view them there.
Posted on Apr 22, 2013
Model dc164. How do I view photos without memory card?
That model uses a DVDR/RW type discs plus a memory card (SD, MMC or Sony Memory Sticks). To view photos from the disc simply go into view mode and use the joystick to move to the image you want to view. If you want to transfer images you need the USB cable that came with it and the original software to transfer images from the disc. While capturing video you can snap images but only to a memory card/stick. No card/stick while shooting video, then nothing was captured and the only way you can get any images is transferring a frame(s) from the video using the USB cable and their included software.
Here are links to the manufacturer website where you can still download the software that came with that model and a second link to view/save the manual in PDF format. Information to read in the manual are on pages 95 & 108.
Support DVD Camcorders SCDC164 Samsung Digital Camcorders
http://downloadcenter.samsung.com/content/UM/200704/20070412144931140_AD68-00993F_us_spa_0119.pdf
Nov 25, 2015 | Samsung Cameras
How do I delete photos from the internal memory
Firstly remove the memory card if present. Then use the 'view' command button. This should bring up the photos which are in internal memory, then delete to your heart's content!!
Check out world casio com CASIO
and Support world casio com CASIO
Jul 26, 2015 | Casio Exilim EX-Z57 Digital Camera
Won't take/record photos!
Are you sure it is set to save images to the card and not the camera's internal memory ?
Mar 28, 2017 | Konica Minolta DiMAGE F200 Digital Camera
Hi i cannot import the photoes from the camera to my macair laptop it doesnot have cd drive, what would be the solutin?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
May 31, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Green light on back of camera is flashing and I cannot view my photos
Green light flashing means that the camera is reading the memory card. If it keeps on flashing and flashing means that the camera is trying to read the card and not able to. This means that there is something wrong with the card. You should stick your card into the computer and transfer all your data from the card on to the computer. after all your photos are safe on your computer, put your card back in to the camera. turn the camera on, press the menu button, navigate to the menu that looks like a wrench and in that menu select "Format Memory Card" this will erase and format the card to how it should be. after that, you should be able to view your photos normally. If that doesn't work your card may be faulty and you may have to purchase another memory card.
Note: the camera might not display photos that you downloaded from you computer on to the card, cameras often only display photos that you took with the camera.
Feb 28, 2011 | Nikon D60 Digital Camera
Downloading photos message says format this memory card. Will that erase the photos on the card?
Yes, If you are getting the message then it will erase everything you have stored/saved on the memory card.
There are few possible reasons for this message.
1. Your memory card is full and does not has enough space to store new photos.
2. Your memory card is not fully detected or recognized hence it is asking you to format the card before downloading
There is simple solution to diagnose and find out the problem for both the reasons.
Click Start
Click on My Computer ( or Computer )
You should be able to find the Memory card drive and you should be able to open it
If you are not able to open and view the contents then your PC has not completely recognised the card.
If you are able to view the contents, your memory card is full and does not has space for more photos to store.
Hope this is helpful
Nov 03, 2010 | PNY 2GB microSD Memory Card
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
Screen reading memory card not initialized
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 31, 2008 | Fuji FinePix Z2 Digital Camera
    Will not allow menu/dateset
    carmera wont work on my compertuer.
    Oct 24, 2006 | Fuji FinePix A205 Digital Camera
    How do I use the memory stick?
    Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
    Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
    Apple MacBook Air Logo
    61 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
