Question about Tools & Hardware - Others
What is the meaning of choking? - Tools & Hardware - Others
  • 49 Answers
When using an axe the handle of the axe acts as a leveler allowing you to increase the force at the cutting edge, when you are not using the full length of the handle, you're choking the axe.
Posted on Apr 18, 2013
Honda Dream Yuga choke positions
Hi, Mohammad for cold starts pulling the lever up means the choke is on pushing the lever down means the choke is off and this is the position for normal riding for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://www.google.com/search?q=Honda+Dream+Yuga+choke+positions&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiy1NyujIPTAhUF4yYKHQlwCJQQsAQIGQ&biw=1366&bih=638
What is the choke on off position in passion xpro
Owner Manual Dream YugaK14A Tire
http://www.partsfish.com/page/oem-parts-for-honda
https://docs.google.com/file/d/0B-lYH6KUBDy_Mkl5S2kzTzB1cmM/view
Apr 01, 2017 | Honda Motorcycles
It will idol when choked apon release motor revs big and stalls
So it idles fine when the choke is on but not when its off, am I correct.
When the choke is on, the butterfly on the carb is closed. Meaning that Air is restricted upon entering the carb. This is telling me you still have a fueling issue. As when the butterfly is closed, the engine is getting the optimum amount of fuel and air to burn. However, when you release the choke, you open up the butterfly on the carb mean more air can get into the carb, in turn this draws more fuel through the carb to create that optimum burn.
Yours however isn't getting the fuel it needs when the butterfly is open, meaning its getting too much air and not enough fuel. Check and clean carb, replace any fatigued gaskets and diaphragms.
Apr 26, 2016 | Echo Used Trimmer Gt200r Outer Drive Tube...
99 FXDWG, Choke cable broke, bike stalled then wouldn't start. I fixed the choke cable but bike still won't start. Any ideas?
"Crank" and "turn over" mean exactly the same thing. I think you mean it won't "fire". How did your choke cable break on the highway? You shouldn't have been pulling (closing) the choke at that point - does that ride have other issues?
It might be flooded now - try letting it sit for several hours, then try starting with the throttle WIDE OPEN and no choke - that helps clear extra gas out of the cylinders.
You might also need to pull the spark plugs and dry them out thoroughly.
Aug 13, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
Ridgid pressure washer motor runs choppy when choke is disengaged
The choke reduces the air flow into the carb. If you are having problems with the choke off, it means that not enough fuel is getting into the engine and it is running lean. When you choke it, the reduced air flow causes the mixture to be correct and it runs fine.
Feb 09, 2014 | Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp...
Engine only runs with choke on. Blue smoke comes out and engine runs rough or not at all
sounds like you have a bad Ring on the Piston or a blown head possibly. Blue smoke means Oil is getting into the combustion chamber. Full choke means you have to give this 'broken' engine a lot of gas to compensate for it's problem.
Do you change the oil at least once a year? Filthy oil or a lack of oil will kill an engine
Aug 06, 2012 | Yard Man Garden
The choke trouble light is on what does it mean and what can result from 600 miles og being ignored
The choke light means that the engine choke is defective, have it checked, it is located on the side of the carburetor.
Jun 25, 2012 | 1989 Chevrolet C3500
Where is the choke located on 99 rebel
what size rebel, when you say the choke do you actually mean the choke lever or the choke mechanism?
Jul 13, 2011 | Honda CB 250 Motorcycles
Cant get it ilde other than when choke is onwhen i cut the choke off bike goes dead and it idles high when choke on
If you have a choke and not an enricher then you have an air intake problem meaning a choke shuts air off.you can pull the carb. and clean making sure all passages are open and clean if that does not do the trick slowly turn your air/fuel miwture screw in alittle at a time until she idles
Jun 23, 2010 | Motorcycles
Tools & Hardware - Others Logo
76 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
