Question about Tools & Hardware - Others
What are the uses of mortising axe? - Tools & Hardware - Others
    Problem Solver:
  • 47 Answers
Mortising Axe is used for creating mortises, a process which begins by drilling two holes at the ends of the intended mortise. Then the wood between the holes is removed with the mortising axe.
Posted on Apr 18, 2013
Which axe should I use for chopping?
For fine chopping using a side axe this sometimes is a positive effect however, felling with a double bitted axe is not recommended because it's extremely reduces the efficiency.
Apr 18, 2013 | Tools & Hardware - Others
What is the meaning of choking?
When using an axe the handle of the axe acts as a leveler allowing you to increase the force at the cutting edge, when you are not using the full length of the handle, you're choking the axe.
What is a Carpenters axe?
A carpenter's axe is a small axe, usually slightly larger than a hatchet, used in traditional woodwork, joinery and log-building. The poll is designed for use as a hammer.
What is the use of broad axes?
Broad axes are used with the grain of the wood for more precise cutting. Broad axe bits are most commonly chisel-shaped
Feb 03, 2013 | Garden
What is the purpose of splitting axes?
Splitting axe is used in wood splitting to split the grain of the wood. Splitting axe bits are more wedged shaped.
What is a mortiser?
A mortiser is a woodworking tool used to make shapes such as rectangles and squares.
Jan 31, 2013 | Drills
I purchased the delta mortising attachement and bits to use on my shopsmith drill press. As usual with the shopsmith, nothing but their products fit exactly. However with a few adjustmests I have it set...
They make special vises for drill presses. once attached your surface is adjustibal from 0 to 90 dergees. Spme accessories you atach to the plate will allow x and y movement by turning the handle so if you get both there is no angle you can't work...just like a machinest.
Aug 03, 2009 | Delta Mortising Attachment
I would like to install a used mortise lock in an old door which has the cut out for a smaller mortise lock. I am hoping to use a power tool and not a chizel because the door is a 100 year old hard wood...
Can't think of a bit which will do what you want but you could stitch drill it to the desired size then chisel the holes square this should reduce any chance of cracking
Jun 29, 2009 | Eagle EKB-2020 Key-2020 Key Box w/ Mortise...
Purchased Delta Mortising tool for delta drill press
go to youtube, get to expert village type in how to run a mortising tool, watch the vidio , you can learn a lot about power tools there.
Apr 11, 2009 | Delta Mortising Attachment
Tools & Hardware - Others Logo
94 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
