Question about LG 42PG20 42 in. Plasma HDTV
I have a lg ty 42PG20D and have sound but no picture
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Wont retain audio settings
Try just using the optical cable alone. connecting the HDMI and the optical cables at the same time might be confusing the TV.
Mar 27, 2017 | LG 42LC2D 42 in. LCD HDTV
I have a LG 42PG20D with a one inch brite white stripe, going from top to bottom about 3/4 along the screen on the right side
That vertical stripe is not fixable in plasma TVs.
Well, easily 99% of them.
The reason is that what goes bad is actually embedded in the display itself and not subject to servicing or replacement.
1% , possibly less, of the plasma TVs out there have that part outside of the display and as such subject to replacement.
Sorry for the new and please do not kill the messenger!
http://www.coppelltvrepair.com
Nov 09, 2012 | LG 42PG20 42 in. Plasma HDTV
PT-52LCX66-K picture is darker than normal...
Sounds like you need to replace your lamp. The lamp number for this panasonic TV is TY-LA1001. Lamps run anywhere from $120-$250.
Nov 12, 2008 | Panasonic PT-52LCX66 Projection Television
Sound but no picture
It's most probable that your lamp is busted, since the tv didn't went out completely. Replace the lamp and you'll be fine :)
Sep 01, 2008 | Panasonic PT-53WX53 53" Rear Projection...
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
LG RZ 37LZ55 37 in HDTV LCD Screen Dead
This is likely due to a failed power supply. Replacing the power supply board should solve the problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy
Jan 10, 2008 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Have sound no picture
hi there, you maybe have a defective parts at the horrizontal section, or some cold solder, loose connection inside the unit. do some check-up, cleaning and testing. ty
Jan 10, 2008 | RCA P52937 52" Rear Projection Television
LG 42PG20 42 in. Plasma HDTV Logo
88 people viewed this question
Computer Repairing
Computer Repairing
