Question about AOC 177S-1 Monitor
How to disassemble a AOC 177Sa-1 Black 17" LCD Monitor
Removing back cover
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor - Manuel
I assume you only found the 4 mount screws in the back... You also need to take off the front silver edging - it pops off with some negotiating, but if you find the right spots and don't pry hard it will come off clean without too much difficulty. Then take out the screws that hold the screen inside and it should drop out.
SOURCE: lm720a 17" monitor switches it's self
Does omebody knows a repair manual for this monitor ??
Posted on Apr 28, 2008
SOURCE: drivers
Go to your monitor resolution and change it lower. Then change the refresh rate if you need to/
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future. If you need more help, feel free to keep asking, but keep the original information so I can see it.
Posted on Jun 06, 2008
  • 111 Answers
SOURCE: How do i take the back off of my AOC 17
Ik think you should remove some screws. after that, most of the times there are clips that holds the two parts together. The best you can do, is squeeze a guitar pic or so betweer the panels, and twist the guitar pick. That will do the job.
I said a guitra pick, but it can be anything. As long as it is flat and thin.
Posted on Apr 22, 2010
Plug was cut from monitor cable
You don't specify which cable was cut but the easiest repair is to replace the complete cable unless, of course, your AOC monitor has an attached cable that does not disconnect. If that's the case, you'll have to disassemble your monitor enough to access to the internal connections and install a replacement cable
Apr 08, 2013 | AOC 177SA-1 (BLACK) Monitor
I have a AOC 177sa-1 Monitor with a bad light bulb where can I buy a replacement so I can get it fix
WWW.LCDPARTS.NET
Are you sure that the lamps are bad, very delicate repair works.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 16, 2011 | AOC 177SA-1 (BLACK) Monitor
Sound is not working
make sur that sound run correctly (no mute,....)make sure that the sound card driver is installed correctly if no you have to downlowd it from website of your pc manufacturer then try to change cable.
Dec 23, 2010 | AOC 177Sa 17" LCD Monitor
AOC LCD monitor black out..Please help? I'm having some problems with my monitor, from time to time my monitor just blacks out, the whole screen turns black, but the computer is still on....and i'm forced...
Sounds like bad video card drivers..Try updating the drivers from the manufacturer's website. Give us the details of your video card/ PC.
Or it could be monitor related. Open the monitor and check the power supply. Make sure there are no bad capacitors inside. If you find any replace them with new ones with same number or bigger capacity,
Apr 02, 2010 | AOC LM720 17" Flat Panel LCD Monitor
Monitor flickering
Monitor flickering can be one or several problems.
Depending upon the age of the unit and value, you should decide weather to repair it or replace it.!
More than likely, it is a problem in your power supply.
The capacitors in the supply will leak and most often crown.
If when you start unit after sitting for a while, it shows good and then after a few minutes it starts flickering, you can bet it is one or several capacitors in the supply.
This monitor is a 17 inch and not really worth the time and investment to repair, unless you have the technical skills to remove and replace electronic components.
Nov 05, 2009 | AOC 177Sa 17" LCD Monitor
AOC LM729 17" LCD Monitor Screen goes black
YOU HAVE A DRY SOLDER PROBLEM, You have to open the monitor and check the solders in the PC BOARD , mainly where theres A SMALL transformer resolder it , and try again ,that should fix it . hope it helps
Apr 20, 2008 | AOC LM729 17" LCD Monitor
AOC LM942
ok grab the plastic peace covering the bracket screw.. Squeeze it and pop it off.. Held on by plastic tabs..
you will need a good grip
Feb 10, 2008 | AOC LM942 (Black) 19" LCD Monitor
Jan 26, 2008 | AOC LM729 17" LCD Monitor
Lm720a 17" monitor switches it's self
try to resolder all lost contact on flyback transformer..............................
Oct 11, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
AOC 177S-1 Monitor Logo
49 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
