Question about Miele Vacuums
Miele s500 wouldn't turn on?
Just wouldn't switch on -hours after using normally
  • 1 more comment
  • Les Dickinson
    Les Dickinson Apr 18, 2013
    sorry wrong link it's this one > http://www.miele.co.uk/Resources/Operati...
  • Julie Apr 18, 2013
    It is a Miele cylinder cleaner "Solution 500" or S500. Thank you.
  • Les Dickinson
    Exhaust filter change indicator reset button needs to be pressed
  • Miele Master
  • 18,392 Answers
Try pressing the reset button ,this link is the manual and will explain about filter reset,
http://www.instructionsmanuals.com/u2/pdf/aspiradoras/Miele-S500-en.pdf
Posted on Apr 18, 2013
  • 1 more comment
    thanks very much -sadly our model doesn't have a reset switch so back to square 1!!
  • Les Dickinson
    what model is it
  • Julie Apr 19, 2013
    Many thanks for your time -machine was taken to bits last night, cleaned and reassembled; seems to be ok now I'm glad to say!
Is it possible to vacume water with the miele slaris turbo plus?
I wouldn\'t attempt that unless it says you can do that in the manual. Use a steam cleaner. They are made to suck up water.
May 18, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Blows hepa filter from mounting
I have seen generic filters do this. Be sure to use original Miele filters. The generics are a few dollars cheaper to buy but you end up with an inferior quality filter that could cause other problems by continued use. same is true with bags.
A clogged filter may also do this. Miele vacuums are very tightly sealed, the exhaust air has to come out. If the filter is clogged, the pressure could pop the filter out, HEPA filters are suggested to change out about every 50 hours, for most people this is between 1 - 1.5 years.
We had a Miele come in for service the other day with the same complaint, installed filter was a generic, customer said it was a new filter just installed. We replaced with an original filter and problem ceased.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 16, 2013 | Miele CatAndDog700 Bagged Canister Vacuum
Where do you put the prefilter on a miele canaster vaccuum
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Sep 11, 2012 | Miele S514 Solaris Electro Plus Vacuum
Miele Callisto keeps turning itself off and has poor suction
Hi there, You don't actually specify how long it takes to turn off but this is normally due to a blockage in the hose or due to excessively dirty filters. Given that you have said the suction is low i would be inclined to think you have a blockage in your hose. Remove the hose and test suction of the machine again. If you have a notable improvement it is telling you something is stuck in the hose which you will need to remove.
May 22, 2012 | Miele Vacuums
Miele revolution 5000 no power light flashing
I would refer to your owner's manual. If the manual has no resolution, then I would contact the manufacturer directly.
May 08, 2012 | Miele Vacuums
6 yr old Aqualisa shower working perfectly well. But turned itself on last night. No light showing on dial/on switch. Wouldn't turn "off" for me. Ran for 15mins and then switched off!
Good Aternoon lrmulholland,
Do you know what model Aqualisa shower you have or are you able to take a photo of it for us? That would be very useful.
Kind Regards,
The Aqualisa Team
Sep 07, 2011 | Vacuums
Is there a Miele Turbobrush to fit my Miele Vacuums cleaner model S274I
The STB205-2 is the turbobrush for that model. Here are a few links to some websites that sell them.
http://www.centralvacuumstores.com/item.php?id=4557
http://www.amazon.com/Miele-STB205-2-Turbobrush-S500-S600/dp/B0017PNLC6/ref=sr_1_5?ie=UTF8&s=home-garden&qid=1256095892&sr=8-5
http://statevacuum.com/shopcart.asp?prod=Turbo+Brush+STB+205-3&qty=1&price=$129.00&code=sv
http://www.totalvac.com/miele_attachments.htm
Oct 20, 2009 | Miele Vacuums
My vacuum (miele s251i) will not turn on. I just changed the filters and bag. Just wondering if I have put the top filter in the wrong spot. Does it go under the black flip-up bit or on top of it? I do not...
Hello Miller_04,
Regardless of how the filter is put in the vacuum cleaner should turn on. Really is no way to put the filter wrong in these. I have a white star myself.
You can contact Miele Vacuum support and they can further troubleshoot or recommend a vacuum shop in your area to send it to for repairs
Miele Dealer Locator (vacuums: non repair)
(800) 579-4583
Monday-Sunday: 24 hours Miele Dealer Locator (vacuums)
(888) 785-2828
Sep 16, 2009 | Miele S251i Plus Bagged Canister Vacuum
Miele Red Star Powerhead overheats and turns off
be sure at 1st there is no materials blocking the hose then it seems to me your m/c is good if normall condition around
try to test your cleaner by use less length hoses
thanks
Jul 04, 2009 | Miele Red Star Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
239 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
