Error code 6 on york diamond 90 furnace - Heating & Cooling
  • 20 Answers
That relates to a pressure switch fault. Unless you own, and know how to properly use a manometer this could easily be mis diagnosed. You have a combustion blower inside the top cabinet, and coming off either the blower assembly, or the cold end header box it's attached to there will be a round plastic pressure switch. It will have 2-3 wires, and 1-2 plastic hoses coming off. Depending if it's a single, or two stage model it may have two pressure switches, one for low fire, and the other for high fire. The switch will have a rating in "WC on it. If there's one hose going to the pressure switch, remove it from the pressure switch and attach it to a manometer. If you read a bigger number the switch is bad, if it's lower look for blockages in the vent, and intake pipes. If there's two hoses off the pressure switch then the difference in pressure has to be greater than the rating on the switch. Good luck!
Posted on Apr 19, 2013
milten1
  • 1304 Answers
SOURCE: I have a york diamond 90 diagnostic 1 flash lock
open the top of your unit so that you can see into the burner box
what your looking for should be an orange wire that leeads up to a metal rod
that metal rod should be in the way of the flame when unit is on
this is your flame ground,,, or more commonly known as the flame sensor,,, take this out and goive it a good brush with some steel wool
and reassemble,,
this should clear up you problem
Posted on Nov 04, 2009
  • 3249 Answers
SOURCE: York, diamond 90 heating issues, on & off
try cleaning the flame sensor with some steel wool if not could be pcb
Posted on May 23, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: York Diamond 80 furnace (propane conversion),
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Posted on Dec 28, 2009
heatman101
  • 43501 Answers
SOURCE: Main blower fan is not starting on my York Diamond
Check to see if the blower motor is actually getting power to it...You will have to check for power on the heating speed terminal... and the neutral wires....you should have 120v across those two wires....
If you have power then the motor is bad...if no power then the heating relay went bad on the circuit board and you will have to replace the circuit board...
That is a common problem as those relays are often to light and wear out...
Just realize that without an electrical meter to trace things through you are really just grabbing at possibilities and not really able to correctly diagnose your problem...
heatman101
Posted on Dec 08, 2010
  • 1033 Answers
SOURCE: York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Posted on Nov 27, 2012
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
Does a york diamond 80 furnace have a pilot light?
There is a diagnostic code flashed from a window in front panel of the furnace. What is it? From your description, I would bet on the ignitor as faulty. The vidoe shows this repair. Don't remove elements and sand them as this fixer did. it is destructive in many cases. York Diamond 80 furnace troubleshooting won start won light flame sensor...
Mar 08, 2018 | Heating & Cooling
Nov 27, 2012 | Heating & Cooling
Where is the pilot on the york diamond 90 furnace
there is no standing pilot on your 90% AFUE furnace this is a hot surface ignition
Mar 05, 2011 | Heating & Cooling
York, diamond 90 heating issues! Ruscopeland suggested to check out problem by noting fault code on the system... after it turned off it kept flashing 6 times. what does this mean? any answers?
Look at the electrical schematic on the inside cover to the electrical compartment. It should have a list of fault codes. Locate the condesate drain lines (up to three) and remove them and inspect them for debris/blockage. Clean them and flush them with warm water and clorox solution. Make sure that your condensate line is not blocked and that you are getting drainage from the condensate line. The new high efficiency furnaces generate a great deal of condensate water from the burner and it needs to drain properly.
Jan 28, 2011 | Heating & Cooling
May 23, 2010 | Heating & Cooling
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
York
I have an old York outside compressor/coil/fan unit, CDHF36-6A, that I need to replace as it is no longer repairable. What is the capacity of this unit and what Carrier unit would be a good replacement?
Adair
Oct 31, 2007 | Heating & Cooling
Heating & Cooling Logo
316 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
