Question about Hotpoint WMA64 Front Load Washer
Change Bearings for HotPoint WMA62N
Hi
My Hotpoint machine has given up on me. It makes loud noises when in Wash. I removed toe cover to see if I can find any problems. I spinned the drum by hand and it was still making noise. So I removed the belt and spinned again and still there was nosie. So I summarised that there is a fault with bearings.
Can anyone help me in providing instructions on how to replace bearings? Do I need to remove the drum completely to change bearings or am I able to do it without removing the drum?
Thanks in advance. Dhar.
  • craigsbolton Mar 31, 2009
    Hi, I also have the same issue. I have pulled a few panels off to look inside and everything looks ok. When I rotate the drum, it feels a little rough so I've summised that the bearings need replacing. Looking online, the bearing kit is quite cheap but I'm unsure of how easy it is to replace. From looking at the way the hotpoint is made, it looks like a complicate job as there is no access from the back.
    Craig
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi, I also have the bearing problem on a hotpoint wma and have just stated the repair job. I have found the following on different forums, so maybe it might help others. You do need to remove the drum and there are two different sizes of bearings 30mm and 35mm. To find the size you need you have to get to the bearings and measure them.
. Ok,Hotpoint wma series drum bearing failure.Firstly very common problem since i work on these things every day-i think there is a design fault-nothing new in this trade!What follows is
the sequence of problems in changing the drum bearings:If the machine has been thrashed into oblivion just changing the oilseal/bearings will have you back to square one within a
couple of months since you would`ve damaged the drum shaft as the bigger bearing of the 2 goes into shapnell mode!So you`d best change the drum shaft(in the trade known as the
spider) however this thing is aluminium usually held onto the the drum via torx headed screws either in steel or soft Al2 also-forget it as your not going to get these out unless your mega
lucky,what we do at work is to replace the whole tank/drum/bearing assembly which comes with a new element and belt ie the whole tank unit,the trade price of this part is less than
£100.00-you can draw your own conclusions as to the retail price as you wish.If you haven`t thrashed the machine you can get away with replacing just the bearings or easier still the rear
half of the tank(trade price 30.00+vat) in which the bearings are already fitted via the factory and reuse the existing spider/drum shaft so long as it isn`t damaged by disintergrated bearing
shapnell.I hope this clears up this problem for you.Please note that this machine`s filter which is at the rear doubles up as the air trap-the oval section 8" long semi transpatent plastic tube
thing-the part that allows the water to compress the air so turning off the level of fill at the right level via the round swt behind the soap dispenser-called the pressure swt-if the filter gets
bunged up the machine o/fills and either overfills or overfills and floods or tries to spin with aload of water still inside the drum or perhaps no spin at all.Hope this helps someone.
The drum comes out through the front on this one. Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band
holding door seal & peel seal back. Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side & slide to right to remove being careful with board &
wiring. Remove screws holding top end of front then lift slightly &remove front. Remove back panel & take wiring off heating element & pump. Disconnect the pump hose at the drum end,
disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then
carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
Posted on May 13, 2009
Hotpoint WT965 is making a loud noise when spinnig
Suspect bearings. With door open wiggle the top of the silver drum If it moves up and down inside the tub, replace the bearings
May 15, 2012 | Washing Machines
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Our Hotpoint WF321 1200 spin is just 3 years old and now makes a very loud noise when in use - both for the washing and spin cycles. is the drum loose / off balance? any help appareciated
Remove lower rear cover of washer, remove drive belt, and from the front spin drum by hand, if it feels rough, or is rumbling, or noisy, then the main drum bearings are failing.
This is a major repair!!!.
Mar 13, 2010 | Hotpoint Washing Machines
Very noisy when Hotpoint Aquarius WMA46 is on spin
It is the main drum bearings that is causing the noise.
There is no provision made for lubrication.
It can be done as a DIY fix, but it is a very involved repair, as it means having to remove the whole inner workings of the washer,
Not a task I would recommend unless you know what you are doing, and feel competent to tackle it.
Good luck.
Dec 05, 2009 | Hotpoint Washing Machines
A hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
Jan 02, 2009 | Washing Machines
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ultima WF840
all i can suggest with the info you have given, is to remove the lid and check for anything lose like the weight block etc also have you checked the inner drum for play, maybe the bearings have gone please not to all it is not safe to continue to run machines that are making noises, they can only get worse making more damage, what can start off as something silly can eventually write off the machine start with that and see how you go, glad to help, if i have helped please rate me
Oct 03, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
446 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
