Question about Neff H5470 Microwave Oven
Microwave makes a crackling sound when I am using it
Everything is working on my microwave apart from your sound it makes. It is an elderly microwave
Is it normal for a microwave to make crackling noises when standing and not in use but plugged in ?
A microwave in standby mode should not crackle. There might be a slight humming sound from a transformer, but that should be all the noise it makes. You could have a transformer or control panel component that is failing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Oct 28, 2016 | In Microwave Ovens
Rattling, crackling type noise just started and is constant when microwave is running.
A couple of months ago my microwave started making crackling, rattling and grinding sounds everytime i used it and i thought it was going to break down. It turned out one of my children must have spillled or overflowed something with a clear liquid because the micro did not look dirty but there was a crunchy substance under the wheels of the turntable. Once i cleaned this up totally the noises all went away.
Jan 19, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My microwave is making a cracking sound like if it had metal in it but i took everything out and its still making the cracking sound. What could be causing this sounds if microwave is empty?
A contaminated wave guide cover will crackle and spark.
They should be periodically checked, cleaned or replaced.
Contact Maytag for replacement parts.
Hope this fixes your noise.
Nov 27, 2010 | Maytag MMV5207AAS Microwave Oven
After a few seconds my microwave makes a crackling
check for scraps of foil, wire ties any type of metal or tin,or aluminumif not any of that, ur looking at a componet problem
May 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not heat. Everything else works. What is the most common problem?
Disconnect power source. Take the case cover off. Inside you will find a high voltage fuse. This is probably your problem. Use safety current tools to avoid an earth shaking electrical buzz.
Elder
Feb 23, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Turned microwave on this morning ,sudden crackle,then nothing.
Sounds like something has shorted out-blown. Unless it is a very expensive model it won't be worth fixing and is not something you should attempt yourself anyway. If under guarantee then get it repaired via the guarantee arrangements. No harm in checking the plug is wired properly but as the light and timer are working it is very doubtful it is a connection problem. I think you need to buy a new microwave!
Oct 03, 2009 | Electrolux EMS2487X Convection Microwave...
No Power
It sounds like the fuse blew inside the unit. It can be replaced, but you need to find out what caused it. There are also thermal switches that will turn off the unit if it overheats. They are called "snap discs" because they have only one setting and will shut the unit down to protect it.
If you aren't familiar with this kind of work, do not attempt repairs. Take it to an appliance shop. It could be anything and a competent appliance shop will tell you if it's worth fixing.
Mar 22, 2009 | GE Microwave Ovens
Neff H5470 Microwave Oven Logo
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
