Question about Kyocera Mita KM-1635 Copier Drum Unit Black MK410
Kyocera km 1635 shows error message c6050 - Kyocera Mita KM-1635 Copier Drum Unit Black MK410
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I HAVE A PHOTOCOPIER MACHINE KYOCERA KM 1635, DOES
According to the manual you can not scan with it. Sorry. Also here is the manual if you need it.
http://www.kyoceramita.eu/dlc/eu/documentation/usermanual/km-1635-2035-og-uk.-downloadcenteritem-Single-File.downloadcenteritem.tmp/KM-1635-2035-OG-UK.pdf
Good luck and please rate
Posted on Sep 16, 2009
Testimonial: "it was100% p"
  • 1833 Answers
SOURCE: How do I clear error message on Kyocera KM
According to you, this C0280 error code indicates the fax board problem. First check all connections of your printer and fax line. You have swapped the fax unit to another printer so now you have to update the firmware of the fax machine. Firmware update is available also at Kyocera website. So upgrade of firmware will solve your problem. If you don't get proper help then you may have to reset your fax settings. After update reboot the machine.
Posted on Jun 24, 2011
Cogz
  • 1326 Answers
SOURCE: what does the error message OP mean on my Kyocera mita KM-1500 copier?
From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
Posted on Dec 20, 2012
Kyocera Mita Km 1635 showing error code A0610 solution
my dear your heater problem rest codes in program 10871087
after press 163 and codes rest
Apr 29, 2015 | Kyocera Office Equipment & Supplies
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
My Kyocera KM-1635 will not allow me type anything after displaying call center C6050
Fusing related problem
: Abnormally low fuser unit thermistor temperature
Replace Fusing Thermistor
Check Thermal cutoff
Replace fuser
Nov 27, 2012 | Kyocera Copystar CS-5035 Copier
My Kyocera KM 1635 / 2035 displays error message: error call 600
Needs a service, either call your photocopier service company or find one on google.
Mar 19, 2012 | Kyocera Office Equipment & Supplies
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
May 25, 2009 | Kyocera Mita KM-2050 Printer
Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Sep 14, 2007 | Office Equipment & Supplies
Kyocera Mita KM-1635 Copier Drum Unit Black MK410 Logo
35 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
