Question about AOC 193FW LCD Monitor
AOC 193FW White Display
My AOC 193FW display is white, i tried opening the case and check the board, i found out that Q203 of the mainboard is burned, i wanna know the value of it so i can replace it, Anybody please help.
I WANT ACER AL1921 DRIVES
Posted on Mar 11, 2009
Dropped my garmin now screen is white and nothing will work
try to open the back cover.. get access to the lcd display. Check if the ribbon wire is properly connected from the mainboard to the lcd display board. Disconnect and reseat properly.
Let me know if I can help you further
Feb 27, 2011 | Garmin nuvi 205 GPS Receiver
Im trying to use my aoc 193fw as an external monitor for my laptop but when i connect both the aoc 193FW does not stay on. It isplays something for 2-3 seconds then goes off. the power button says its on...
You need to find out first if it does the same when attach to another PC, you may have problem with the monitor itself.
If it is the monitor:
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 26, 2011 | AOC 193FW LCD Monitor
My lcd monitor produces only white screen...what should i do???
If you olny getting white glowing screen, it can be the connector to the T-CON board on the LCD panel came off or it has blown fuse on the T-CON board, or the logic board is not sending the 5 or12vdc to the T-CON board.
Please read below:
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Oct 02, 2010 | AOC 193FW LCD Monitor
Walang Display sa pentium4 pero sa pentium3 Display siya
baka di makayanan ng Monitor mo ang required resulotion ng Video Card sa Pentium 4 mo.
if thats the case.. mag down grade ka sa VGA Card ng Pentium 4 mo or Buy a new monitor that fits the specs of your Pentium 4 setup
Jun 01, 2010 | AOC 193FW LCD Monitor
The monitor has an signal, but after 5seconds,,, the display was too dark,,, can you help what is the problem
owns_mon, "Switch-mode-power-supply"/CCFL inverter supply failure." Check your warranty?? Else visit YOUTUBE and more of my FIXYA profile for your options for repair!!! 12fixlouie
Jan 05, 2010 | AOC 193FW LCD Monitor
White Display
Here is two solutions:
1. Grab a LCD Color Tester, Run it through RGB.
- If it is still white its the LCD
-If it not at all either the inverter board is bad or the mainboard.
2. Sometimes its brightness control, look under the manual.
Apr 18, 2009 | Princeton Digital VL1716 17" LCD Monitor
Dropped phone with a white screen
Hello, Your phone's display is operated by 2 separate wire ribbons. One of them sends data to the display's matrix and the other one powers the led backlight. A display doesn't produce light on it's own so instead it utilises some white led's to light up. What you see on the display are actually those led's lighting up from under the display. I supose your problem is with the display connector. However the phone must be dissasembled and the display connector must be checked. In order to do this you will need some T5-T6 screwdrivers (they can be found at most radioshacks or electronics store). Locate the display's connectors and with the phone opened, try to move them around a bit to see if something is showing on the display. Also check all the connectors on the phone mainboard for cracks or other defects. I'm sorry for I can't help you more with this on a simple chat. If you have any questions however, please ask and I will try to guide you through this process.
Sep 09, 2007 | Samsung SGH-D520 Cellular Phone
White light
Phone + Water = Death Most cases of liquid damage cause the phone to die. Replacing the parts of the phone usually exceeds the price of a brand new one. I can only wish you the best of luck in repairing the phone.
Feb 28, 2007 | Nokia 3230
AOC 193FW LCD Monitor Logo
214 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
