Question about Vehicle Parts & Accessories
Security key is not responding .. Cant open my car
Check a battery
Posted on Apr 18, 2013
My car key has a chip in it an i cant open my car door or trunk ,what could be the problem
alot of cars have security chips in the keys and the purpose of this chip is to disable the security locking features such as an immobilizer.
.... however in that car i think most are only fob boards for the remote locking system ensure that if there is a battery in the key/fob that it is not flat.
also note that some keys are designed not to open the trunk but should open the rest of the car.
the general rule of thumb for car locks/systems is;
if the key turns in the lock then it is likely the locking mechanism in the door (if you had another key that worked then you could and should rule this out).
NOTE also lot of car door locks have electrics tied to them these days (hence the drivers door unlocks the whole car), so you still can't rule out the cars security unit or the local master slave units.
.... but if the key does not turn properly or at all, then it is likely the wrong key for that lock, unless the lock is jammed. most locks are designed so only that key or type of key will turn in the barrel of the lock.
Mar 02, 2017 | Cars & Trucks
How do I turn off the flashing security light in my 2002 Sierra Denali?
Dont know if this could help or not but...my jeep grand cherokee security sys i thought was possessed! would not respond and just before i threw a brick thru it lol a guy asked for my keys and proceeded to unlock the hatch..it stopped..then he told me to open my door before he closed the back. Now every time I unlock the hatch first then open the drivers door.who knows- It wont cost you to try. Good luck
Dec 10, 2014 | 2002 GMC Sierra
Battery key fob
Turn the ignition key on , open the hood, disconnect the battery for two minutes, reconnect and try .
Dec 14, 2013 | Prestige Remote Start
How would you hotwire a Mazda b2300 if u lost the key.
cant hotwire your vechicle has the PATS SYSTEM.your keys has transponder on it.the ignition switch antenna ring and immobilizer control module and ECM read signal emitted from the keys transponder if you have no keys or wrong keys the PATS SECURITY SYSTEM DISABLE IGNITION SYSTEM CAR WONT CRANK.CANT HOT WIRE CAR WITH THE PASS KEY SECURITY SYSTEM.older cars back in 70s you could hot wire newer cars you cant.
Apr 05, 2013 | Cars & Trucks
Security system not responding to key fob signal input
When my 1995 Jeep Grand Cherokee will unlock the doors but not deactivate the security system it is always time to change the battery in the key fob. Don't order a new fob, just pry the fob open (carefully) and replace the battery. I buy mine from Batteries + and they cost like $.80 a piece + tax.
Jun 22, 2011 | 1997 Jeep Grand Cherokee
How do i get the security system out of valet mode?
From remote: press F twice on the remote then unlock. (F, F, Unlock) From car: have door open, turn key to ignition position (ON), then OFF, then press and release the button on the control center (antenna on the windshield).
hope this helps.
Mar 03, 2011 | 991 Responder LC3 SST Security/Remote...
97 chevy camaro wont start *security light it's on*
power locks check fuse and relay.take car to dearlership.they have to check your theft deterrent module.when its in security mode.your problem could be it cant read the chip on ignition keys or the theft deterrent module is failing.not a home fix.
Jun 22, 2009 | 1997 Chevrolet Camaro
I cant cut off my alarm and car wont start
is ti and aftermarket or factory system, if aftermarket look for little black button under dash or button on antenna, turn key on and press for one full second, if aftermarket unlock door with either trunk or passenger side and try again...
Jan 25, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
77 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
