Question about Sewing Machines
Dont know how to use the sewing machine so how do i thread
Dont know how to use the machine how do i thread a bobbin? and how and where do i find a users manual? So i can use this machine
  • 2 more comments
  • kellnken Mar 11, 2009
    its a pre historic janome my style 20
  • kellnken Mar 12, 2009
    Thank you so much greatly appreciated thank you thank you!!!
  • Anonymous Apr 14, 2009
    janome machine threading bobbin... HELP!!!
  • Jim Scott May 11, 2010
    what is the brand and model please
  • 374 Answers
Well!I If you buy a new sewing machine it has a manual to guide you in any brand.But if buy a used one sometime it doesn't have a manual, you didn't mention the type of sewing machine you want to use any how if you have a mechanical sewing machine it's better to start on it.First you must know and must familiarize the significant part of machine and important usage of them,I'll just mention the most usage part at start.Putting thread in bobbins first there is bobbins winder where thread was wind,draw thread from spool through bobbins winder tension disc located at top of machine.wind thread around an empty bobbins serveral times then,place bobins onto bobbins winder shaft with thread wound on bobbins clockwise sometimes this is located at top right side a shaft coupled to circular rubber touching handwheel perpendicular sometime it was located at right side front of machine near handwheel.Release clutch by pulling handwheelor rotating pivot wheel counterclockwise at the center of handwheel whlle holding freeze the handwheel tigh in order to disingage the motion of handwheel from mechanism of machine.
Posted on Mar 11, 2009
  • Louis Magpantay
    Louis Magpantay Mar 11, 2009
    Push slightly bobiins winder that connected to shaft to attached in handwheel surface, start machine notice that the needle should not move,and the bobbins winder rotate same with the handwheel holding onto end of thread, when bobbins is slightly filled,release and of thread.When bobbins winder is full it will automatically disingage to handwheel surface winding machine.Remove bobbins winder filled of thead and put back or insert inside to bobbins casing the thread end should coming out to the bobbins casing thrugh the slot, pulling out the end of the thread notice that bobbins winder rotate freely inside bobbins casing on clockwise rotation.Insert bobbins casing through shuttle assembly located at front left of machine where needle was there.SEE image if this qualified to attachment its 1.6 mb jpeg.hook up thread on top of machine to set thread in sequence aligntment,Observe the upper tension fromdial tension.As you can see different fabrics and layer thickness of fabric should have different set up of tension.You can experienced accumulation of loof thread under bobbins and shuttle casing due to mis setting up or unsatisfactory tension set up.try to familiarize in setting up tension,cotton/polyester is nice to start sewing other than silk fabric.Set Dial tension @ #3 and stich dial to #8 if loop thread accumulate under bobbins sudden adjust should done Besur to try this machine is not running with plug in or with electrical source mean no power,just use manual rotating in setting up tension.If you feel that the needle is freely sewing and the lower thread is catching upper thead w/out obstruction and accumulation suddenly applly a pedal control pressure,controling the pressure of pedal control the motor run slowly so that if problem occured you can avoid needle breakage.If yo are familiar now in settingup tension run machine w/c convenient to you.
Fabric not moving
You probably lowered the feed dogs; the 'button' is oblong shaped, and to the right of the bobbin case. I have had several Pfaff machines, and still sew with one, so email me if you still have a question. Sheila sheeleigh@yahoo.com
Apr 05, 2014 | PfaFF Sewing Machines
I have a singer 20u, the bobbin always drops when i put it in , i cant sew at all.please let me know how to fix it.
it's very possible that there is something wrong with the bobbin case or the hook & hook race, only a sewing machine shop can tell you for sure what wrong with the machine
May 29, 2012 | Singer 20u Sewing Machine
I just bought my first sewing machine, its a touch & sew duel zig zag sewing machine/model 758 i dont know how to thread it or the bobbin
Call Singer at 1-800-4singer and see if they will send you a manual, in the mean time google how to thread a sewing machine and there are some great videos available for free.
Apr 21, 2011 | Singer Drop-In Bobbin 758B-28BH Mechanical...
I have two problems the first is that as i sew sometimes the fabric on the back side gets stuck and there are many pieces of thread coming up from the bobbin and get stuck the second question is everytime...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Necchi 6011
How do i fill bobbin, thread machine and bobbin?
Did you know all sewing machines are threaded in the same way. The parts just look a little different. If you can thread one machine you can thread them all. Dont you have an instruction book? If not get any instruction book for a simular looking machine. There are many you can dowload for free as a pdf file.
Dec 12, 2010 | Necchi 3610 Sewing Machine
My sewing machine wont sew. the bobbing wont move. i dont know what to do
Make sure the bobbin is NOT overfilled. Make sure the thread leaves the bobbin in the appropriate groove and the CORRECT direction. Leave the right amount of thread out of the bobbin to start and follow the manual's suggestions
Hold the needla thread for a cycle and bring the bobbin thread up before sewing.
Oct 20, 2009 | Singer 7422
How do i thread the bobbin
I have a new sewwing machine Eurp-pro Shark automatic but I don't know to thread the bobbin
Oct 07, 2008 | Sewing Machines
How to thread the machine and bobbin
you can just search the web for the kind of machine you have and there should be a place where you can find a manual. Try ebay, they have just about anything. good luck with your sewing!!!!!!!! sandylou
Dec 08, 2007 | Brother LS-1217 Mechanical Sewing Machine
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Sewing Machines Logo
613 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
