LG WD-8013F Out of balance on spin cycle
Sometimes on the spin cycle the machine violently shakes,moving about the floor.
Have put on level floor etc but still does it.
Looks like a generic fault.
Any ideas.
    Sergeant:
    Champion:
  • 259 Answers
When you are loading the washing try and keep the amount of clothes you load even on all sides also have you tried adjusting the feet ?? we have got a kelvenator smart drive and that is the same
Posted on Mar 11, 2009
  • 27 Answers
You need to ask yourself the following and i know it sounds silly but try it
is the appliance completly level
is the floor substructure level and solid (if its on a floating floor this sometimes happens)
have you tried moving the appliance to a concrete area and tried running it there
what is load like have you balanced the washing load
have you removed all of the transit bolts and securing structures
if you have the appliance on an unstable floor try putting some old worktop/counter top or some 20mm mdf board under it
hope this helps
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
Whirlpool Duet GHW9100LQI. Has been a good machine for many years. In the past year it began vibrating violently on spin. I've watched a ton of videos to diagnose. Possibly the rear bearings? However,...
There are damper weights, usually pieces of concrete/stone attached to the side of the exterior of the tub, have a look to make sure they are not loose, missing, broken etc. Also make sure the 4 main supports (legs) are solid and not loose, cracked or corroded. If it has self leveling rear legs, make sure they are locking into position and not moving.
Mar 04, 2015 | Whirlpool Washing Machines
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Hotpoint wt741 shakes violently
Washers utilize spring loaded legs for self-balancing or threaded screw in feet that uses a manual locking nut.
If unit is level and sitting solid on the floor,you may have a stabilizer issue or a weak wooden floor.
Nov 26, 2017 | Washing Machines
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
LG wm2277hw front load shakes violently
Barry The repairman was right. The drum is out of balance because of the load amount .Thed clothes or items need to be distributed around the drom rather than just throwing in. When it comes to spin the imbalance causes the machine to shake and move across the laudry.
As it sometimes works This is probably when you are not doing a heavy load of washing, so it appears to work OK.
Pack it with less, also adjust the front legs a full turn higher than the rear so prevent walking when it spins.If you cant find the spanner that was included , just use an adjustable one.
Aug 21, 2009 | LG Washing Machines
Violent shaking on spin cycle
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
hi all you poor owners of this heap of junk, i have one too with the same problems, the shaking and moving around the bathroom was stopped by welding a 1/2 inch long piece of 1 &1/2 inch dia pipe to a 2 inch square flat plate of steel then putting double sided sticky tape beetween the plate and the floor
where you want the front rubber legs to sit, this stops it from running around the floor but it still needs to adjusted to have the
same on the front two legs to stop the shaking.by leaning the machine back a bit also helps to stop it leaking so bad while filling, it is only from the condersation from the hot water going in and the poor design of the soap drawer not allowing the water to run back into the washer which can be fixed by cutting the lip off
the bottom wher the drawer slides in then running a bead of silcone in the crack between the front cover and the inside piece
then another one on the front edge to run the water back into the washer. hpoe this helps. bryan.
Dec 01, 2007 | Washing Machines
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
