Question about Igloo Cooler Igloo 45075 60 Qt. Island Breeze Wheeled Cooler
The handle wont engage to go down
When i grip the handle in order to push it down, it won't push in the four metal buttons on the handle that allows it to slide down.
We bungied a long toy beach shovel to it.
Posted on Jun 26, 2016
How to fold mia moda 3 wheeler
Step 1
Inspect the stroller's wheels and handle to identify the type of brake mechanism it has. If the device is equipped with wheel-mounted brake levers and swivel locks, use the toe of your shoe to activate these mechanisms. If your stroller is equipped with a handle-mounted brake lever, push down on the lever to engage the brakes. Some models also come equipped with a secondary-locking mechanism located on one of the rear crossbars; use the toe of your shoe to activate this feature.
Step 2
Lift the handle or press the tab securing the backrest in place, located on the upper edge of the backrest or on the crossbars securing the rear of the backrest to the frame. Grip the edges of the footrest, then lower the component by pushing it into the desired position. Pull back the stroller's canopy.
Step 3
Grip the stroller's handle and lift the device upward; if the stroller comes equipped with a safety button, press the button as you lift. Use the toe of your shoe to push on the stroller's hinges until the frame begins to fold.
Step 4
Pull the halves of the stroller's frame together until you have completely folded the device; if the stroller comes equipped with a locking latch, engage the latch to keep the halves from sliding apart.
Audi Parts
May 23, 2012 | MIA MODA Atmosferra Travel System Stroller
2002 1.3 Kia Rio. Pushed in clutch pedal, heard metallic pop, half a piece of a metal ring + half a clip sitting in driver's footwell. Pedal will depress and release but clutch wont engage
I had this same problem the cable is fine its a clip on outer cable to stop it mooving when you press clutch mine poped when I tightened the clutch cable still don't have solution though waiting to payday to take it to garage
Mar 22, 2012 | 2002 Kia Rio
I have a Delta single handle pull down sink faucet (about 1995 vintage) which is secured below the sink with a C-clamp. Below that clamp on the threaded shaft is what appears to be a metal sleeve (about...
It is probably rusted in place. I would recommend that you spray down with wd-40 or similar,tap on it lightly and let set for 10-15 mins. Then try to remove. If it still won't come off I would repeat a few more times if you are wanting to save the faucet.If not you can grip it with a small pair of vise grips and break off stud.You may also be able to remove it from the base of the faucet as it is screwed into it. Good luck and thank you.
Jun 01, 2011 | Delta Home
How do you set the clock on a yamaha stratoliner?
When you get to the clock, push and hold the button. The hour will flash - bump the button to go up. To get to the minute, push and hold again to get to the minutes, bump to go up. This is the method for the few Yamahas I have messed with although I've never messed with this particular model - but it's worth a try..
Scott
May 17, 2011 | Yamaha Stratoliner S Motorcycles
I have a quinny zapp and it is folded down. i can not get the button on the side to work to unfold it. can this be fixed?
Sometimes a piece of fabric gets stuck or something else...It might help to push the frame a bit more together before pushing the buttons.
Did you mention the buttons being numbered?Follow the number you can read. The ones you can read when it's folded are in a different order than what you can read when it's not.
Normally when you follow the numbers you just have to push each button once, then pull back both handles to unfold the back. Then pull the "grip" underneath the cetral tube untill it clicks.Then straighten the hinged bar between the handles.
Hope this helps!
Apr 26, 2011 | Quinny ZAPP Stroller
How do i fold this puschair up & how does it fold down? Can this done by one person? Thnk you for any help.
The Tracker is designed to be folded and unfolded easily, by one person.
To unfold: If your Tracker has an adjustable handle, ensure that it is in one of the middle positions. On the central twist grip, push in the red button and turn the grip in the direction of the "FOLD" arrow. The pushchair should now begin to open. Placing your hand on the side moulding, pull on the handle until the primary locks on both the left and right hand sides engage with a click. The secondary lock should automatically engage.
To fold: First of all, make sure that the front wheels have been locked into fixed, non-steering mode. Also, ensure that the adjustable handle is in one of the middle positions. Press the red button on the twist grip and simultaneously turn it in the direction of the "FOLD" arrow. At this point, the chair should start to close. Next, look for the secondary locking device. This plastic tab should be situated just below the handle grip on the left-hand side. Pull it upwards, whilst tilting the chassis forwards and continuing the folding action until it is fully closed. Align the front wheel with your foot, if necessary, and fold down the adjustable handle to store the chassis.
Find out more by obtaining an instruction manual from service@bebecar.co.uk
Aug 31, 2010 | Bebecar Tracker Urbano 1455-U Stroller
I havr bought secondhand Greco pushchair for grandson, and cannot collapse it! can you help
On the handle of the stroller/pushchair there should be a grip that has a red button. Push the button and twist the grip away from you. There should also be a red grip on the side of the stroller about half way down. Pull that and twist the handle at the same time and push the stroller down. It should collapse.
Aug 06, 2010 | Graco Baby Gear
How do you put up the bebecar tracker urbano? This one is folded and we cant get it up.
If your Tracker has an adjustable handle, ensure that it is in one of the middle positions. On the central twist grip, push in the red button and turn the grip in the direction of the "FOLD" arrow. The pushchair should now begin to open. Placing your hand on the side moulding, pull on the handle until the primary locks on both the left and right hand sides engage with a click. The secondary lock should automatically engage. Find out more by obtaining an instruction manual from service@bebecar.co.uk
Jul 30, 2010 | Bebecar Tracker Urbano 1455-U Stroller
Four wheel drive wont engage
If you have push button 4-Wheel Drive, it is recommended that you use it every once in a while, in order to keep gunk, rust, and corrosion to build up on moving parts. The mostly likeley (though not definite) reason would be that you let the 4-wheel drive unused for so long that corrosion has built up on the parts and the actuator that engages the 4-Wheel Drive doesn't have the power to engage it past the corrosion. You'll need to take it in to be cleaned, or to have parts replaced. In the future, every month or so, engage 4-Wheel Drive and drive around in some mud, grass, sand, or any other loose ground for a bit, just to keep the parts moving and clean.
The service Four wheel drive light is to alert the operator the system is not being read properly by the ECU.
If the ECU loses contact with or position of the Transfer case actuator motor the service light will come on. Same thing goes for the front diff actuator.
So it may be a bad switch, sensor, or an actual problem in the 4WD linkage. This is not a Oil Change light that you can ignore a few extra weeks - it indicates a problem that should be taken care of ASAP to avoid costlier problems down the road.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 21, 2009 | 2004 Chevrolet Suburban
Need instructions on hold to fold my stroller
This is designed for folding with one hand. On the handle there is a red grip. Below the grip there is a button. While pushing this button, turn the red grip clockwise and push down. The stroller will fold. -Vish
May 07, 2007 | Kolcraft Lite Sport XT 46826 Stroller
Igloo Cooler Igloo 45075 60 Qt. Island Breeze Wheeled Cooler Logo
616 people viewed this question
Top Igloo Cooler Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Igloo Cooler Measuring Tool and Sensor Expert? Answer questions, earn points and help others
