Question about Intel D101GGC Motherboard
Cpu my cpu some times produce too much noise,what is the reason,also give me the way to solve it
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
The noise is coming from fan friction and vibration. Running compressed air through fan components can help reduce noise pollution from dust buildup. Brush-less CPU/GPU fans are significantly quieter than the brush-motor powered fans that come with some factory electronics. Furthermore, some computer cases are designed with noise reduction in mind; Antec designed cases are know for being one of the quietest because they use patented bushings to secure the computer hardware. Moreover, make sure internal wiring is free and clear of all fan blades.
Posted on Mar 11, 2009
My cpu fan produces noise while i use the system
Its probably the bearings going out in the fan. Replace it if it gets bad. newegg.com has great deals on cpu and case fans.
Jun 11, 2011 | Balance CP4401 PC Desktop
Gateway 500XL .. sounds like the Power Supply was making a scratching grinding noise.. off/on... I first thought it was the CPU fan and changed it .. not solved... the PC just shut down... maybe...
Very easy to replace power supply as this is most likely the reason for the shut down due to heat. Make sure when ordering new power supply or buying from a computer parts store that you do not relay on them to give you the right one, you have to do your homework, after you get it do not unplug everything from the mother board, take your time and make sure that when you unplug you know where to plug back and wear anti static bracelet.
May 18, 2011 | Gateway 500XL PC Desktop
Hp 2730p fan noise
Laptop Fan noise:
This seems to be a common problem with laptops over a couple of years old. Dust gets trapped in the copper fins and the fan of the CPU heatsink and reduces the efficiency of the cooling, which results in regular power off's by the laptop as it gets over it's upper temperature setting. The fix is relatively easy, just remove the heatsink unit, blow it clean with compressed air, clean the old CPU heatsink paste off with isopropyl alcohol (IPA) and spray a thin film of heatsink paste on the CPU.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Jo
Feb 12, 2011 | HP EliteBook 2730p Notebook
Cpu fan is making much noise even i changed it.
First open your cup and clean the fan with vaccume cleaner.
and check the cpu fan speed if required change the cpu fan.
May 19, 2010 | Asrock 845GV (P4I45GV) Motherboard
My cpu fan's speed is very high. i will produce too much noice. can i reduce my fan's speed?? if i reduced that then what happened?? is there any problem????
On my computer when I first power up the display screen gives me the main board details and an option to change settings on it by pressing an F Key. Does your computer do the same? If it does you should press the key and it will give you the options to control and alter things like fan speeds. Don't forget to check if dust or something else is causing the noise.
Sep 06, 2009 | Biostar P4M800-M7A Motherboard
New cpu fan has 3 prong connecter, old has 4. what is,or does the 4th blue wire have to be connected?
You can connect the CPU fan as normal but it can only run at one speed and voltage hence only having 3 wires.
Your other CPU fan which had 4 wire was able to run at 2 different voltages and speeds and are mainly used to keep the noise down and run quietly.
Regards.
Jul 10, 2009 | eMachines T5048 PC Desktop
No Display on IBM G42 CRT Monitor's screen
if u change monitor . you came to know fault of monitor or cpu., if monitor works cpu is not woking properly..some itime we face same problem to creat by changining highgraphic. we can reduce graohic by using f8. re instiling xp we can solve that type of some problem.
Jun 15, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
Computer is not functioning
H!
Please check the lock of your processor. If it is tight or loose. If it is loose then it is the one causing the mother board no to function properly. You must tighten it to make it stable. After checking and it is not the reason for the malfunctioning of the system. Try to remove your CMOS battery and then clean, and remove also your memory card in the mother board and clean. Return it after cleaning and then close the CPU and turn it on. During the booting process strike the delete key to enter into bios set up. Adjust the time/ date settings to your current time. Press F10 then enter. wait for the CPU to process.
Please post any comment if it was solve so that I can give you more option if it does not solve your problem.
jonags3
Apr 17, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Aspire 5002 WLMi getting turnoff
There is a CD tool called "Ultimate Boot CD" which can be downloaded athttp://www.ultimatebootcd.com. On this CD there are quite a few toolsthat you can use to test your RAM, CPU, Hard Drive, etc.. for problems.Just boot up with this CD and select the corresponding testing programto use. Test each component until you find the component causing the issue.
Cause it seems something is overheating.. Probably the CPU.
Aug 18, 2008 | Acer Aspire 5002WLMi Notebook
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Intel D101GGC Motherboard Logo
138 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
