Question about Motorsports
Vacuum lines. On a 1995 ford escort1.9 engine
Spark plugs with wires were replaced. Starts great idles smooth but when put into drive it shudders then dies but restarts smooth.it doesn't do it if its put into reverse.i looked at engine to look for unplugged vacuum lines and found one missing a hose.its a small fitting on the right top of motor but I see no hose in the vicinity
    Sergeant:
  • 352 Answers
OBVIOUSLY, YOU HAVE A STALLING UNDER LOAD ISSUE. CONSULT SHOP MANUAL TROUBLESHOOTING SECTION
Posted on Jul 26, 2013
2 Suggested Answers
gazzzz42
  • 63 Answers
SOURCE: broken vacuum flap for defrost on 1997 jeep wrangler repairable?
yes parts are easily accsessable online,check make and model
Posted on Nov 01, 2012
67 ford f100 240motor/staright 6 truck starts but dies at idle. Things replaced: -spark plugs -spark wire -fuel filter Any suggestions of what may be causing the truck not to stay on?
carb settings such as idle mixture screw, choke settings, vacuum leaks at base or vacuum lines.Does it stay running off idle?
Sep 27, 2014 | Cars & Trucks
Rough idle
Try changing the plug wires and see if it makes a difference.
Nov 28, 2013 | Road Mice 1995 Ford Mustang Cobra...
I have a 1997 lumina with 3.1L. the problem started with loss of power under load and p0300 code. check coils and vacuum leaks both OK.change spark plugs and wires.[same problem] check compression OK.
Since you changed the sensor we will assume it is working. When you disconnect it you put the computer in limp mode which stops it from using sensor values. If code 300 is the only code we will assume the coolant temp sensor and others are ok.
I would check fuel pressure with a gauge next.
Aug 21, 2012 | 1997 Chevrolet Lumina
Car had code p0300 and p0303 which i do believe are engine misfire codes according to my code reader i replaced plugs with platinum plugs, new wires and replaced all 3 coils. Now all i get is code p0303....
303 IS CYLINDER #3 WITCH IS REAR BANK IN THE MIDDLE, TRY SWAPPING SPARK PLUG WIRES WITH ANOTHER CYLINDER AND SEE IF YOU GET ANOTHER CODE. MAKE SURE PLUGS ARE GAPPED CORRECTLY. IF IT IS NOT A SPARK PLUG OR WIRE, SUSPECT A BAD INJECTOR. 301-306 IS CYL,1-6. ALSO MAKE SURE THE PLUG WIRE GOT BACK ON THE PLUG CORRECTLY THEY ARE HARD TO REACH AND YOU MAY HAVE MISSED THE SPARK PLUG WHEN YOU PUT THE WIRE ON.
Dec 19, 2010 | 1999 Chevrolet Malibu
My 2002 Ford Expedition shakes when put in drive. In park it does not shake. What would cause this, spark plug wires, plugs, fuel filter?
Spark plugs and wires,
Bad or leaky vacuum line
Bad 02 sensors, (check engine light would likely be on)
If it doesn't do it at idle, then motors mounts should be good and the problem is one of the listed above.
Jul 22, 2010 | 2002 Ford Expedition
ENGINE IDLES ROUGH, BUT RUNS FINE WHILE DRIVING. My car is a 1995 Buick Regal Gran Sport with the 3800 series motor with 212000 miles. The rough idle tarted after driving through some muddy and wet roads
go the cheapest route. replace fuel filter and add SEAFOAM to tank of premiun fuel. replace filter before 500 miles. then add SEAFOAM to gas every 3000 miles to keep lines.engine,fuel pump, and emissions systems clean, ETHANOL problem number 3000
Aug 29, 2009 | 1995 Buick Regal
Code PO0171 & PO0174
You have a vacuum leak. Did you use new intake manifold gaskets and torque the bolts according to the spec? Did you get all of the vacuum lines back on in the right places?
Aug 31, 2017 | 2000 Ford Explorer
Motorsports Logo
65 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
