Satellite motor light up once now not working at all ???
  • 3 more comments
  • jomossi Mar 11, 2009
    i have tried this already and the green light came on when i fitted cables now wont come on at all it
    sorry it is a fortec star diseqc 1.2 motorized hh motor
    put receiver on standby mode as per instruction manual put cables in and it light up but then i put on satellite bleeper to set up dish and motor and green light went out and now wont come back on even when i set cables back up properly ??
    if the board was not working can it be replaced or need to get new motor
    no reply when problem not found helpful to a point !!!!!!
    Brigadier General:
  • 3,614 Answers
may i know exactly the unit you have there?
Posted on Mar 11, 2009
  • 1 more comment
  • micromaster
    micromaster Mar 11, 2009
    Go out side and connect
    your cables to motor as shown in your installation manual (check that
    the green light is on the underside of the motor where the cables are.
  • micromaster
    could be damaged on the unit power board. what happen or incidents before the problem occur.?
  • micromaster
    power board can be repaired , a this time you better get someone to test it and examine the unit.,
How do I get the fn key&f8 key to work on my cumputer
Hold Fn and tap F8 once you should see a light indicating you WiFi has been turned on on the base of the PC.
Good luck
Aug 17, 2012 | Toshiba Satellite M35X-S311 Notebook
Toshiba satellite A100 dead. orange steady battery light with mains connected and power button lights shift key and 2 function lights - that's it.
It will turn GREEN when the battery is fully-charged.
Is there a problem with the battery not accepting a charge?
Remove the battery, to see if the computer will start without it.
Do these 2 lights just "blink" once, and then go out?
Does a "power" button stay lit?
Have you hired a professional computer technician to trouble-shoot?
Sep 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
98 chev astro van wipers work once in a while. What to do .
With wiper switch on check voltage at wiper harness, if you have voltage then reverse test light at battery and probe wiper housing if test light light up with screw driver ground wiper housing to mounting bolt, if wiper work bad ground, of test light did not light up when testing wiper motor housing for ground and you did have voltage at wiper motor replace motor, it's not going to be a fuse, if fuse was bad wiper would not come on once in a while, now if no voltage any where replace wiper switch.Good luck and hope this was very helpful, thank you for using FixYa.
Jun 02, 2010 | 1998 Chevrolet Astro
When i plug in my toshibba satellite a205, the plug light turns on, but the batery charge lights flashes just once, then goes off. my battery says 2%, not charging. is it a battery or combination laptop...
True turning it on while pluged in but without the battery in. If it works its your battery if not it is you charger or laptop, my bet is on the charger they have a tendancy to go out.
Feb 14, 2010 | Toshiba Satellite A205-S4777 Notebook
My laptop won't charge
You may have a dead cell in the battery try replacing the battery this is often the case. Good luck..
Dec 29, 2009 | Toshiba Satellite U205 Notebook
I have a Toshiba Satellite A55-S1063 the scrren is dim but I can still see using a flashlight. I have had the back light replaced once it worked great for about 2 weeks and then went back to being very...
Hello !
Since the screen is dim, the display's inverter board needs to be replaced.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
Hope this helps.
Dec 01, 2009 | Toshiba Satellite A55-S1063 Notebook
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
