What does the E5 mean in ORILAX air condition split unit
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
hemantraj
  • 638 Answers
SOURCE: Fedders Air conditioner
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
Posted on Jun 07, 2008
alex_salve
  • 78 Answers
SOURCE: My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
Posted on May 17, 2009
SOURCE: I have a Chigo Mini Split KF-32GW/A. What is
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
1、Check whether two sets of plugs on the outlet end of
the motor have loosed from the socket of the
electric control board, insert it firmly when loosing.
2、Check whether the indoor motor has damaged, the
motor should be replaced when it is damaged
3、 Check whether the controllable silicon and other
components on the electric control board have
damaged, replace the controllable silicon or electric
control board when they are damaged.
Posted on Jun 26, 2010
SOURCE: Westpoint Eolia split system air
Pls. let me know power consumption of split cooling system for home used prouducts . thanks
Posted on Dec 03, 2010
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
I'm looking for an enigma split system airconditioner manual-I have an error message E5 with no compressor activity
E5 Communication errorbetween outdoor and indoor. Check output (call) from your indoor unit to out door unit by Volts meter. If no power in out door, you have to check setting of temp whether it's 23 and less than that and also mode in "Cool".
If power is there in out door and fan only running means compressor is tripped by overheated
Dec 16, 2010 | Heating & Cooling
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
Jun 12, 2010 | Heating & Cooling
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
Carrier Air Conditioning error code 5
Carrier A/C split Model # 38KCL112313GP has error code E1 What is that?
Aug 09, 2009 | Carrier Heating & Cooling
Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
