Question about Cats
Cat not use
Measurement resistant
Working on 2003 Lincoln LS 3.0. code p2110; p2107. Customer replaced throttle body
P2110 - Throttle Actuator Control System - Forced Limited RPM. Throttle actuator control system is in FMEM mode of forced limited RPM.
  • PCM damaged
  • Cross wired TACM motor
DTC indicates only that FMEM condition exists, and can be set incombination with DTCS P2100, P2101, or P2107, meaning the ETB faults should be repaired first.
P2107 - Throttle Actuator Control Motor Processor. The ETC control area of the PCM failed self test. Fault could be the result of an incorrect TP command, or the TACM wires shorted together.
  • TACM wire shorted together
  • TACM circuit wires shorted to pwr
  • PCM damaged
  • ETB damaged
An (TACM) circuit PID reading may indicate a fault if available
DV21 CHECK ETC MOTOR FOR SHORT OR OPEN
  • Remove ETC motor harness connector.
  • Measure the resistance between the TACM + and TACM - pins, through the motor.
Is the resistance less than .8 ohms, or greater than 1000 ohms?
Yes No Replace Throttle body assembly. note: Clear DTCS and rerun self test, if DTCS (P2100, P2106, P2112), or (P2100, P2106, P2111, P2112) are output GO to DV22 , for (P2100, P2106, P2107) GO to DV23 , and for (P2100, P2106, P2107, P2111, P2112) GO to DV24 , and for DTCS (P2101, P2106, P2110, P2111, P2112) GO to DV25 . GO to DV22 . DV22 CHECK ETC MOTOR HARNESS FOR OPEN
  • Remove PCM harness connector.
  • Measure the resistance of the TACM+ circuit between the PCM and TACM harness connectors.
  • Measure the resistance of the TACM- circuit between the PCM and TACM harness connectors.
Is the resistance less than 5 ohms?
Yes No GO to DV23 . Repair open circuit. DV23 CHECK ETC MOTOR HARNESS FOR SHORT TO GND, PWR, ETCREF, AND ETCRTN
  • Measure the resistance between the TACM + pin and battery gnd.
  • Measure the resistance between the TACM - pin and battery gnd.
  • Measure the resistance between the TACM + pin and battery pwr.
  • Measure the resistance between the TACM - pin and battery pwr.
  • Measure the resistance between the TACM + pin and ETCRTN.
  • Measure the resistance between the TACM - pin and ETCRTN.
  • Measure the resistance between the TACM + pin and ETCREF.
  • Measure the resistance between the TACM - pin and ETCREF.
Are both resistances greater than 10K ohms?
Yes No GO to DV24 , for P2101, GO to DV25 . Isolate and repair short circuit. DV24 CHECK ETC MOTOR HARNESS FOR CIRCUITS SHORTED TOGETHER
  • Measure the resistance between the TACM + pin and TACM- pin.
Is the resistance greater than 10K ohms?
Yes No GO to DV25 . Isolate and repair short circuit. DV25 CHECK FOR CROSSWIRED ETC MOTOR HARNESS
Yes No GO to DV26 . Properly wire the TACM per TACM and PCM connector diagrams. DV26 SELF TEST VEHICLE
  • Key On Engine Off.
  • Clear DTCS.
  • Cycle accelerator pedal to the floor and back several times.
  • Self Test vehicle noting any DTCS.
Were there any DTCS related to the ETC system?
Yes No Intermittent fault, GO to Z1 Replace PCM.
Oct 13, 2017 | Lincoln Cars & Trucks
How do I measure ohms in distance
Ohms is a measure of resistance as in an electrical resistor. Wire also has very small resistance but a long length of wire can equal a fair bit of resistance.
Now, to your question, you can't measure ohms in feet - unless you know the resistance per foot of wire (as an example).
Feb 16, 2015 | Cooper Industries Cooper Wiring 2158V 3...
Does cat flea develop resistance to anti-flea products?
There are some cases that one cat flea product wouldn't work properly against cat flea. If this is your scenario, you should rotate to different types of cat flea product each week this way you'll reduce the cat flea resistance significantly.
Aug 14, 2012 | Pets - Others
Motor reves up high when started can not keep it running because its reved up so high
First check to make sure the throttle return springs are closing the throttle. If that's good, the problem is likely a bad idle air control valve/motor. Take the valve out and check for obstructions in the port that could keep the valve from closing. Then, if you have an ohmmeter, you can run these checks on the valve:
    IAC location:
    Remove IAC, check for obstructions in passage, run electrical testsjturcotte_551.gif
    1. Disengage the IAC electrical connector.
    2. Using an ohmmeter, measure the resistance between IAC terminals A and B . Next measure the resistance between terminals C and D .
    3. Verify that the resistance between both sets of IAC terminals is 20-80 ohms. If the resistance is not as specified, the IAC may be faulty.
    4. Measure the resistance between IAC terminals B and C . Next measure the resistance between terminals A and D .
    5. Verify that the resistance between both sets of IAC terminals is infinite. If the resistance is not infinite, the IAC may be faulty.
    6. Also, with a small mirror, inspect IAC air inlet passage and pintle for debris. Clean as necessary, as this can cause IAC malfunction.
Dec 19, 2010 | 1997 Chevrolet Cavalier
Engine management light stays on garage said it was code 420 one garage said **** the cat converter emissions another garage said lambda sensor bank 1 which is it
It is usually the catalytic converter, but sometimes it is the oxygen sensor. If you have an volt/ohmmeter, you can check the sensor. Unfortunately I cannot access your wiring diagram, so I cannot tell you which terminals are which on the sensor. There are 4 pins in the plug. Check 2 at a time for resistance. When you find 2 that have a resistance of about 2-5 ohms, those are the heater terminals. Your sensor heater seems to be working. So, then you want to check the voltage on the other 2 terminals while someone revs the engine up and down. If you have more questions, please let me know. Here are testing instructions from autozone.com:
  1. Disconnect the Heated Oxygen Sensor (HO2S). Measure resistance between PWR and GND (heater) terminals of the sensor.
  2. With the engine hot-to-warm, the resistance should be 5-30 ohms.
  3. At room temperature, the resistance should be 2-5 ohms. If the readings are within specification, the sensor's heater element is okay.
  4. With the O2S connected and engine running, measure voltage with a DVOM by backprobing the SIG RTN wire of the oxygen sensor connector. The voltage readings at idle should stay below 1 volt. When the speed is increased or decreased, the voltage should fluctuate between 0 and 1 volt; if so, the sensor is okay.
Oct 13, 2010 | 2004 Ford Fusion
I can't read the OHMs on a resister in my panisonic tv (pt-51hx41e) resister board # is R7053
I suggest you take it out or just disconnect only one leg and measure the resistance by a multimeter/AVO-meter. If you test it in-circuit you might not get the actual resistance because some other component might interfere with the measuring process! By the way just to mention, there are expensive instruments that are capable of measuring the resistance in-circuit (you could use it if you have one)!
wish you success!
Bruce
Dec 07, 2009 | Panasonic Televison & Video
- will not idle at proper setting, stalls when put into gear
Check for vacuum leaks and test the idle air conrtol valve.
0900c1528006c55b-lxsvs4ftyjtcqsaualeaxmu4-4-0.gif TESTING
See Figure 2
  2. Using an ohmmeter, measure the resistance between IAC terminals A and B. Next measure the resistance between terminals C and D.
  4. Measure the resistance between IAC terminals B and C. Next measure the resistance between terminals A and D.
Do It Yourself Diagnosis and Repair
Sep 02, 2017 | 1987 GMC VanDura
Half way throu my dishwashers cycle it fuses & turns everything in house off
this happens due to the high electric current requirement of the dishwasher and it is not receiving that required current so it try to start but due to lack of required power it shuts off the current in whole house.
get the electric curren line checked out in your house.
and to check the current in your dishwasher check out this instructions
You will most commonly measure two electrical parameters when you're troubleshooting your appliance: resistance (measured on units called "ohms") and voltage. Typically, both of these measurements are made on a single meter called a multi-meter, which you can set to measure either ohms or voltage.
This shows how to measure resistance. Resistance ( or continuity ) is measured in units called "ohms." You'll commonly want to know the resistance of things like bake elements and solenoid coils. For example, a good bake element typically has a resistance of about 30 ohms. If your oven's not baking and you measure the resistance of the bake element and the meter doesn't move, then you know you have a bad element. A simple ohm measurement can save a lot of money and a possible headache :)
Amp meter: Here's a clamp-on amp meter (or amp meter) being used to measure current flow through a wire. This is a common test for determining whether or not a gas oven igniter is good or bad--only way to really know is by measuring its current draw and comparing to rated draw. You'll also want to measure current/amp draw in cases where you have an electric motor that runs for a few minutes then shuts off on it's built in safety to see if the problem is with the motor drawing excessive current.
Volt meter: This picture shows how to measure voltage. A voltage measurement at the outlet should the first thing you do whenever you have an appliance that is completely inoperative...a simple power test is required if your electric dryer is running with no heat to make sure you have both powers at the dryer
thanks.
Oct 16, 2008 | Dishwashers
1996 hyudai accent
CHECKING IGNITION COILS
1. Measurement of the primary coil resistance. Measure the resistance between connector terminals 3 and 1 (the coils at the No. 1 and No. 4 cylinder sides) of the ignition coil, and between terminals 3 and 2 (the coils at the No. 2 and No. 3 cylinder sides).
2. Measurement of the secondary coil resistance. Measure the resistance between the high-voltage terminal for the No. 1 and No. 4 cylinders, and between the high-voltage terminals for the No. 2 and No. 3 cylinders. Be sure, when measuring the resistance of the secondary coil, to disconnect the connector of the ignition coil.959e0ec.gif
CHECKING SPARK PLUG CABLES 1. Check the cap and outer shell for cracks. 2. Measure the resistance Spark plug cable (SOHC)
Resistance should not be higher than 10,000Ω per foot of cable. If resistance is higher, replace the cable.
Aug 13, 2008 | 1996 Hyundai Accent
Cats Logo
109 people viewed this question
Top Cats Experts
Ruth summersides
Tom Chichester
RANDY POWERS
Level 1 Expert
Are you a Cat Expert? Answer questions, earn points and help others
