Asrock conroe b65gv motherboard only working cpu fan.....
No display, no light on keyboard... pls help me.
  • Computers & ... Master
  • 5,660 Answers
First thing to check with a desktop computer problem is the Power Supply.
This I state a lot.
In reality there's a flaw.........
In reality a person should visual check for bad capacitors on the motherboard, then move to the Power Supply.
The AsRock Conroe865GV uses nothing but Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitors to be exact)
Doesn't use any Solid Polymer Capacitors.
These are known to be a 'weak link' on a motherboard.
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
Capacitors are used as Filters, and Voltage Regulators, on the motherboard.
The ones used as voltage regulators are in the Motherboard Voltage Regulator Circuit,
http://www.hardwaresecrets.com/article/616
Just thought you might like to know
Since you indicate the CPU fan is spinning, I assume you know the computer isn't supposed to be dirty inside.
If you don't............we need to have a long talk..........
With a Power Supply having a weak voltage power rail, you may see LED's light, and maybe fan's spin, but there won't be enough power to turn the CPU (Processor) on.
1) If ALL of the LED's were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical CPU (Processor) can use 51 to 130 Watts. Just depends on what CPU it is.
AsRock Conroe865GV?
http://www.asrock.com/MB/overview.asp?Model=ConRoe865GV
The motherboard chipset is an Intel 865GV chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Can support Intel Pentium 4 HT, models 620 through 672; for ->one.
They can use Up To 115 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
[ AsRock Support states the Conroe865GV will support Intel Core 2 processors, but I don't believe it.
It isn't until you get to the Intel 945G, that Core2 support is picked up.
Just my 2 cents ]
High voltage AC electricity comes into the Power Supply, and is contained in it's metal case.
The AC voltage is converted into low DC Voltages.
3.3 Volts DC, 5 Volts DC, and 12 Volts DC.
In comparison two D cell flashlight batteries produce 3 Volts DC.
A multimeter is used to check the three voltages.
Need guidance with this post back in a Comment.
[An economical multimeter around here, can be purchased for around $5 to $12.
Available in a lot of stores. I have seen them on checkout aisle racks, of major discount stores ]
OR;
Use a KNOWN to be good, Compatible power supply for a test unit.
May be a working computer that is not being used, that you can Temporarily borrow it's power supply.
Let's start the diagnosis from here..........
Post back in a Comment
Regards,
joecoolvette
Posted on Apr 18, 2013
map9966
  • 2351 Answers
SOURCE: Asrock 775 vmb Motherboard
Sorry randar, I need more information about the board. You can look here at Asrock's link.
http://www.asrock.com/support/download.asp?c=775
This pade shows all their Socket 775's.
Now you understand why I asked for more info!
Posted on Feb 21, 2008
freetek
  • 5568 Answers
SOURCE: MOTHERBOARD PVCLE266M-L MERCURY V3.0A------ HELP HELP-------
The first board may be bad; the detection of input devices is done by chips other than the uProcessor.
The second board may simply be controlling the fan speed according to need and when first powered up, the processor isn't hot.
Posted on Aug 28, 2008
v_suspect
  • 27 Answers
SOURCE: No beep,No Display on my monitor,only CPU heatsink fan is moving
Obviously, it could be a transcient error or what we call the soft error. There could only be two culprits if you encountered this kind of problem. One is, it could be the power supply. If the power supply is faulty the electricity that flows within it (which is AC converted to DC)could have a lower or higher amount of electricity instead of a normal rate.
But if your PSU is working properly ( you could check it by swapping the PSU to another system unit ) then it could be the MOBO. According to standard IBM POST error codes, no beeping sound could be a faulty PSU or MOBO. It is more practical but to replace the MOBO, but still you could use the memory, videocard, HDD and other devices.
Posted on Sep 05, 2008
revskank
  • 203 Answers
SOURCE: asrock conroe 1333 d667 R1 driver
all the drivers for that motherboard are available from this link
http://www.asrock.com/mb/download.asp?Model=K7VM3
Posted on Feb 25, 2009
rasengan79
  • 138 Answers
SOURCE: No Display in ASRock 775i45GV Motherboard
Try cleaning the RAM as shown in the image below:
also you can try resetting the CMOS, here's how it's done on your motherboard:
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes system
setup information such as system password, date, time, and system setup parameters. To
clear and reset the system parameters to default setup, please turn off the computer and
unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3
seconds. Please remember to remove the jumper cap after clearing the CMOS.
The location of the CLRCMOS0 on the motherboard can be seen on the image below. (labeled no.10)
If problems persist. Replace the RAM. Hope this helps.
Posted on Oct 08, 2009
Conroe b65gv fsb800
http://europe.asrock.com/MB/overview.asp?cat=Manual&Model=P4i45E%20R3.0
Jan 05, 2014 | Asrock P4I45E-R3 P4 845E FSB800 DDR400...
No display (black screen)when i put a radeon hd 5450 (pcie 2.1) on asrock conroe 945pl-GLAN how can this be solved?
I was swapping graphics cards and i had the same problem. I just had to be persistent. I had to try booting up i heard some error beeps. I waited 5 minutes to give the bios time to update i rebooted two or three times more before it worked
Nov 26, 2013 | Asrock ConRoe945PL-GLAN (4711140874418)...
I have the asrock conroe 1333_d667 motherboard in my computer but i opened my computer and took out one of the ram sticks looked at it and placed it back now when i turn on my computer it dose not show on...
Look that you correctly inserted the RAM-module, it should "click" in place.
if you still get no display, turn the computer off, remove the power cord and remove the CMOS/BIOS-battery for 1 minute and then connect everything an try again!.
May 20, 2011 | Asrock ConRoe1333-D667 Motherboard
Cpu fan is making much noise even i changed it.
First open your cup and clean the fan with vaccume cleaner.
and check the cpu fan speed if required change the cpu fan.
May 19, 2010 | Asrock 845GV (P4I45GV) Motherboard
AsRock Motherboard won't boot. Need Advice.
Here's the solution!
Check if NUM lock glows if tapped on the Keyboard ::
Yes - If your Power LED is blinking change the SMPS, if it is Solid, change the I/O cables or RAM or Display Adaptr - whichever you think the problem to be.
N0 - Change the board.
PS. If processor is the problem, CPU fans won't spin in the first place.
Jan 10, 2009 | Computers & Internet
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
Mothrnoard
First thing to check here is the connection make sure everything is still properly connected, if after checking it and still no light it only means the motherboard is dead and already needs a replacement, because if the power supply is bad the fan shouldn't spin if its the problem...
Hope that helps...............
Sep 17, 2008 | Asrock P4i65GV Motherboard
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
