Question about Haier Heating & Cooling
I have an ORILAX Air Condition split unit 24000, the system display E-5 and not blow warm air, can I have help.
It gave me warm air I check the gas it ok and i replaced the small cylender "Protector" but still give me warm air.
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
  • 6 Answers
SOURCE: fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Posted on Feb 16, 2009
SOURCE: Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
Posted on Apr 05, 2009
james3751
  • 614 Answers
SOURCE: central air unit only blows warm air , when set on cold
First check to see if your outside unit is working and you can here the compressor running. If the fan runs and the compressor does not you have a problem with the capacitor or wires burnt off terminals. If your not sure you know how to work on this please call a service tech ask for free estimate. If the unit compressor and fan runs you may be out of gas that meanns you have a leak. Either way you need a service tech. You can only go so far without the correct tools to work with. Russ
Posted on Jul 22, 2009
  • 81 Answers
SOURCE: blowing out warm air
This could be a refrigerant leak. Before you call out a service technician, clean the filters and then try to see if it works. If it doesn't then get the unit serviced.
Hope this helps
I take the time to answer your questions, so please rate me.
Mat
Posted on Aug 30, 2009
Outside unit turns on and runs for a long time by itself then shuts off. Does this all day an night long. Notice this after a circuit breaker tripped. Not breaker to unit though. Other parts of house.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other Air Conditioning Repair help. Check us out online.
Jul 25, 2016 | Celiera Celi 24000 BTU Ductless Mini Split...
My tadiran split system air conditioner is blowing warm air
if its warm air like really hot then you switched the unit to heat mode
if its blowing air in room tempereture then there is a gas leak somewhere ,so you'll have to find the leak source and after that fill the unit with freon gas.
Aug 26, 2014 | Heating & Cooling
My new LG mini split 24,000 BTU unit is Freezing up on the small tube side. Not cooling properly. I thought freezing up (low on freon) but wouldnt it be on the larger tube. Is it running the fluid...
The larger tube is the return tube for the hot freon gas from the evaporator. The small tube is the cold freon after is has gone through the condenser where gas is condensed to a liquid when the heat is removed. So I would say your system is low on freon.
Jun 09, 2011 | LG LM-2430H2L 24000 BTU Heat and Cool Dual...
I have a split unit airconditioner 12000btu.It worked great for about almost 5months.till yesterday,when I turned on the air con,I didn't feel cold.I just felt normal wind blowing.then after 5min a...
E-4 ..........short of asor no gas
Please check amps with amps meter reading. If very less amps than specified, it's under gas leak. Even you can physically touch the discharge (small) pipe while running, if it's not warm, gas leak. Call repairman to check and arrest gas leak and then recharge gas.
Helpful?
Dec 25, 2010 | Heating & Cooling
Good after noon i have a Starway Split Wall Mount Reverse Cycle Air Con. the problem i have is when i need to warm my house the air coming from the system is cold. even with the temp setting on the sun...
Examine the condenser. The condenser pushes the air and expels the warm air from the air condition to the house. Also check the fan heater on your system to see if it is functioning, because if it is not, it will circulate the heat from the unit to the house, in this case,it will need to be fixed. also check if the thermostat on the unit is regulating because if it is not regulating, you will not get the house to warm due to bad thermostat, check to ensure it is regulating, if not, replace it, it might be defected because that is the key to regulate the unit. so pay attention to it to see if it regulating the unit, if not, replace as advice.
Take care.
Jun 12, 2010 | Heating & Cooling
My fujitsu split system blows warm air after about
There is not really enough information here to properly answer your question. I can make a couple of observations for you though. 1. Compressor, yes this could be the problem, but it is not quite that simple. Is the compressor running when the hot air starts to blow? 2. Capacitor, no I don't believe this is the problem, as if it were a capacitor problem, chances are the unit wouldn't even start. 3. Gas leak, again no, if it were a gas leak, then you wouldn't get an hour of good run time when the unit starts up, repeatedly. Hope this helps.
May 07, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
