Question about Fuji FinePix S2 Pro Digital Camera
Hi there. A mystery error shows the Display of my Finepix S2 pro. Its like that: "o - -" or "o _ _" in the upper Display. Has anyone an idea for that? Best regards, Harry
Checked out the following: - Crad slot (working) - Objective thread (working) - other displays (working) - power cells / batteries (working) - Lithium cells (working) - used another Objective (working) - closing funktion of the cf-card slot (working) - checked the error codes ..... didn't find helpful things uahhhgh , can anyone help me? thx in anvance harry
  • harald hartig
    harald hartig Apr 18, 2013
    Thanks, i tried this but the error "o_ _" still occures...
  • harald hartig
    Umm... maybe the AF-motor ? any suggetsions ?
  • Fuji Master
  • 32,281 Answers
Try resetting the camera by removing the battery for 15 mins. Replace the battery then go to the camera's Menu and scroll through the settings to set the Date and Time.
Posted on Apr 18, 2013
  • harald hartig
4 Suggested Answers
  • 1382 Answers
SOURCE: Fuji FinePix S2 Pro
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Posted on Jun 25, 2010
SOURCE: Fuji FinePix S2 Pro won't turn on
Do you remember what did they do to reset the camera ? Can you share, please ?
Posted on Dec 08, 2010
Tri3mast
  • 747 Answers
SOURCE: My fuji finepix S2 pro
This is an old post but if you haven't found your solution yet here is the solution.
The Fuji FinePix S2 Pro uses two sets of batteries one set located in the camera body grip and another set in the battery grip itself. If you are experiencing the problem you are then the batteries in the camera body are dead and need replacement. here is a diagram. Replacing the batteries in the camera body require removing the grip.
Diagram
Posted on Jan 11, 2011
My fuji finepix S2 pro camera can not turn on when i put 2 cr batteries into its grip, when i remove 2 cr batteries it's turn on and work but i can't using flash, error no cr batteries found. Please show...
Diagram
Jan 06, 2011 | Fuji FinePix S2 Pro Digital Camera
How do i fix high saturation
Press the Func. button to diplay color modes in the little display.
When the display shows Color to the far left, you can switch color modes on the button below. STD is standard saturation, HIGH is high saturation, ORG. is less saturated that STD, and finally B/W
Jul 06, 2010 | Fuji FinePix S2 Pro Digital Camera
Weird colors in viewfinder
Sounds to me like a CCD problem, which is a bad thing. CCD faults were quite common in the early S2's. It would be worth contacting Fuji about.
can you insert a few images into the thread to have a look at. Need more than one to check consistency of problem.
Sep 08, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji finepix s2 pro
the lithium batteries power the flash and some of the metering. But if they drop below a certain power, the camera dies. The F33 error is probably the accidental movement of the aperture ring on the lense. If you get the error, check the aperture ring is set.
Aug 11, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji Finepix S2 Pro
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 - image records in black
Could be CCD Failure ... known as ' Black Screen of Death'.
Have CCD cleaned at a reputable camera (not chain) shop and they'll test it.
Fuji were replacing units suffering this problem at one stage.
May 05, 2008 | Fuji FinePix S2 Pro Digital Camera
The Camera Fuji FinePix S2 Pro1 is not starting up
Generally, in indicator on the back display shows empty battery; sometimes after a short a message Err on a display
Feb 24, 2008 | Fuji FinePix S2 Pro Digital Camera
FUJI S2 PRO
Maybe your card is already def.
Aug 08, 2007 | Fuji FinePix S2 Pro Digital Camera
Change MP to 12
If shooting RAW set the resolution to 4256 when using the raw converter. If shooting JPG's set the 4th setting on the function menu to 4256.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
119 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
