Projector lamp flicker after half an hour usage
  • 1 more comment
  • Paul Margiotta Apr 24, 2013
    there are only on/standby controls on the actual projector - so I can't reboot as suggested? also when flickering the projector makes a kind of gurgling sound? (!!)
    what is lamp driver ballast? thanks p
  • jvsvisual
    jvsvisual Apr 24, 2013
    It is the main oscillator high voltage unit that drives the lamp which is controlled by the system control on the mother board
  • 29 Answers
Possibly down to lamp or lamp driver ballast
Posted on Apr 18, 2013
SOURCE: Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Posted on Dec 28, 2008
projdoc
  • 2237 Answers
SOURCE: I need to reset the lamp hours on an Hitachi CP X380 projector
hold rown reset on panel for about 3 seconds, wait for display, press reset again and select 0.
Posted on Dec 23, 2009
SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Posted on Dec 06, 2007
SOURCE: reset lamp hours for new bulb
Is it a Sony VPL CS4? Try [Reset], [<-], [->], [Enter] keys
Posted on Sep 29, 2007
SOURCE: Benq PB8220 lamp used for 375 hrs shuts projector automatically
Unplug any cables from the projector (except for power)
On the device (not the remote control) hold down exit for 3 sec
lamp status are shown
on the remote control use MENU, and then left right to reset lamp
Posted on Oct 01, 2009
Why is the light strobing ?
Lamps will sometimes flicker when they are near the end of their life. Look through the menus and check the lamp hours, if it is over 1000 hours I would try another lamp. This could also be caused by the lamp ballast, which is the power supply for the lamp. If the ballast is bad, repairs will cost almost as much as a new projector.
May 01, 2014 | Epson EMP-X3 LCD Projector
Brightness Flickering
1,the mother board is good
2,the lamp ballast is good
3,the lamp is defective, replace it with a new bulb ,
you need a new Original lamp (USD290)
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 24, 2014 | Sharp Office Equipment & Supplies
Benq w1000 projector
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Feb 07, 2014 | Office Equipment & Supplies
Need to reset lamp usage time without the remote on NEC VT490
Hello
Press the MENU button on the projector's control panel to display menu options.Press UP/DOWN button to reach the RESET option window. There you can see Clear Lamp Hours and Clear Filter Hours option. Select the Clear Lamp Hour option and press enter. That is all. OK.
Oct 22, 2011 | NEC VT490 LCD Projector
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
Microtek cx6
I've had the same problem with my projector three times (usually whenever there's a sports championship). You just need to call optoma, get an RMA number, and ship it to them. Theoretically they'll fix it under warranty and send it back free.
May 02, 2008 | Optoma HD72 Multimedia Projector
Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
Feb 18, 2008 | Sharp Projector lamp Projector Lamp
Reset lamp hours for new bulb
Aug 18, 2007 | Philips UGO X-Lite Impact Multimedia...
k24674
jasbo
jasbo
