Digital read out changed on its own. Need to know how to change it back to fahrenheit. Whirlpool acq128xro
SOURCE: AC Thermostat
If you have a maual go to the installer settings, Most manufacture have these manuals online
SOURCE: Thermostat reading
inside of most stats there is a switch that changes for F to C. some stats you have to into the installer set up program to fix it. if I knew what kind of stat i could maybe walk ya through it.
SOURCE: How can you change the temperature settings to
Press < and > at a time for 5 seconds continuously.
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
If [230] appears on the
display screen, then the temperature is set to Celsius. To change back
to Fahrenheit:
1. Turn off your flat iron and unplug from electrical
socket (wait for 10secs).
2. Then plug the iron back into the electrical socket.
3. Press
& hold down the HIGH [?]button, then press ON/OFF button. An "F" will appear on the
digital screen. Your device is now in Fahrenheit mode.
