Question about Compaq Presario 5000 PC Desktop
Monitor gets off; colour is changing
When system is switched on and monitor is kept on ,the monitor gets switched off on its own while booting;
earlier when system is on the coplour of the monitor changes automatically to black
  • twineman89 May 11, 2010
    Does the monitor come back on after rebooting on it's own or does it stay shut off?
    Also what monitor are you using?
  • 118 Answers
Check the data cable from the monitor to the system if there is any loose connectivity, this kind of prob may occur coz of connectivity of the cable,
Posted on Mar 23, 2009
Will not cme on
Hi
Firstly - Is the cabling, mains and data cable, securely attached at both ends and the power turned on at the mains?
Secondly - If so when you press the monitor power button, does a light come on? (often orange coloured) If yes does this change colour when the computer starts its boot sequence? (often to green or blue)?
If no light can be obtained it is likely that the monitor is faulty.
If a light comes up on power up, but doesn't change colour during the computer boot sequence then it is more likely to be the graphics card that is faulty, or sometimes the computer PSU.
The easiest way to find out whether the computer or monitor is at fault is to replace the existing monitor with a monitor that is known to be in full working order, for example from another computer. (Or connecting your monitor to a computer that is known to be working)
Having isolated the faulty component it can be replaced and you should be up and running again.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 18, 2014 | GNR TS902D Monitor
Thin vertical colour bars from top to bottom across full width of screen
Welcome to FixYa,
Below are the top reasons why there are "colour bars" running across the screen :
  1. Corrupted video driver
  2. Changes in hardware configuration (display)
  3. Monitor issue (hardware)
In order to determine if it's hardware/software issue, all you need to do is to boot to BIOS and check if the problem replicates. Depending on system, you can go to the BIOS screen by tapping "F2" or "DEL" key repeatedly as soon as you turn on the computer until you see a different screen.
If the problem is present while in BIOS, then definitely the monitor needs to be repaired by an authorized repair center. Otherwise, video driver update or Operating system re-install can resolve this problem.
Hope this helps,
Thank you for using FixYa.
Jul 26, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor problem
Your monitor is sensitive to magnetic interference from your pc speakers, place them away from the monitor at all times then the montor should go back to normal within a few hours or so. you could try to degause it every couple of hours or so but this will not totally fix the problem, leaving the monitor switched off for a period should work better.
Jun 27, 2010 | Computers & Internet
Monitor will come on briefly then turn back off, what could be the problem?
A distinct possibility would be a resolution error in the operating system. Try booting in "Safe Mode" (I assume you use Windows), and see if it works. If it does, change the resolution to something safe, such as 1024 x 768 by 16 million colours (24 bit), or even lower. Then boot normally. At that point, increase gradually the resolution.
Jun 17, 2010 | Advueu Technology ADV178T 17" Flat Panel...
My computer will turn on but my monitor does not get a signal and I've tried this on two working monitors and two different power chords. The lights on the keyboards don't even work. Any solution?
I was just dealing with this last night. My pc would come on, but I kept getting a "No Signal" message on my monitor. I first plugged the machine into a known working monitor. It worked fine so that eliminated the video card issue. Then I plugged the monitor into a different computer...it too worked. So I knew that the monitor was good. I then switched the cord from the faulty monitor and still didn't get a signal. I proceeded investigating the issue. I found that if you boot the machine in safe mode, it actually caught a signal. So...I figured it must be something to do with the resolution. My solution: Boot the machine in safe mode, change the resolution in the control panel and reboot the machine. If it doesnt catch the signal booting in safe mode, I suspect it is a faulty video card. You are likely to find what you are looking for online at zipzoomfly.com or newegg.com
May 20, 2010 | E-Machines eMachines Desktop PC
Monitor won't start when I boot up - without a lot of fiddling!
First try to do monitor self test.Disconnected the blue cable VGA or white colour connector from monitor to the computer. Turn on the monitor and check if you are able to see colours or line on the monitor.Indicating self test monitor is working fine. If you are using Video card on computer connect monitor directly to onboard video and check. Good Luck.
Aug 19, 2009 | Computers & Internet
Green screen and attempting to switch monitor on
Click the Menu and try to degauss the monitor . Do u have any speakers kept near the monitor do keep away from the monitor,
Dec 16, 2008 | LG Studioworks 700S 17" CRT Monitor
Dell E196FP TCo99 Monitor screen problems
The screen colour changing is apparently an auto test procedure on the monitor and was prompted by a fault with the monitor not automatically shutting down when the computer is shut down. The settings on the monitor have been adjusted to rectify this and the problem is now gone.
Apr 06, 2008 | Dell E196FP 19" LCD Monitor
Acer AL1511 15" monitor Screen Menu Problem
What operating system do you use? If it is a windows OS press F8 while the system is booting to access the Boot Manager, choose to boot to last known good configuration and if this does not work retry but select safe mode and change the resolution back to the previous one.
Jan 19, 2008 | Acer AL1511 15" LCD Monitor
Monitor goes blurry, colours/pixels start shaking across screen
Do you have your screen saver enabled, i so turn it off and se if it still does it. Secondly boot your pc in safe mode(pressing F8) on boot up and select start windows in safe mode. See if the monitor still does it, if so a monitor fault or loose/faulty vga lead. If it is ok then your graphics driver may be corrupt and need re installing.
Dec 30, 2006 | BenQ FP71E 17" LCD Monitor
Compaq Presario 5000 PC Desktop Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
