Question about Mitsubishi Heating & Cooling
After a black out the air isnt cold and the motor doesnt run
  • steve
    steve May 11, 2010
    Try resetting the breakers to the unit.
  • 525 Answers
Check :
1. If the main fuse is good
2. check outlet for power
3. Check cable
4.Check for the relay
5. Check the motor for continuity using ohmmeter
6. try the direct running without relay
if run at 6
replace the relay
if not the compressor is to be suspected
All this operation have to be done by a professional only.
Posted on Mar 11, 2009
1999 chevy silverado heater fan only blows cold air , both coolant lines in are hot
I like that you were knowledgeable to check both coolant lines tells me you are getting hot coolant through the heater core next thing to check will be the blend door on the inside of your vehicle. The blend door is a door that switches from cold air duct to heater duct depending on what you are using at the time. If it is stuck on the cold air duct you will not get any heat sometimes these doors are vacuum actuated and sometimes they are electrically actuated most the time you are able to see the movement of the motor from inside if you don't see any movement but you hear it move chances are it is the door blend I hope this helps.
Jan 10, 2013 | 1999 Chevrolet Silverado 1500
A/c blower turns slow and makes puffing sound. bryant 80% avac system.little cold air from vents
Hello, replace the capacitor as when there are storms sometimes they can cause a voltage spike and damage the capacitor. The capcitor will be a round or oval metal looking can next to the motor. When the blower motor runs slow the coil can start to freeze due to lack of airflow and this is why little air is coming out of the vents. If the capacitor does solve the problem then the motor will have to be replaced.
Jul 01, 2012 | Bryant Heating & Cooling
Refrig is not cooling. freezer cold but not freezing. Already cleaned condensor
several potential problems
1) evap fan motor isnt running to circulate air into fresh food side
2) it isnt defrosting (do ya see what looks like snow on back of freezer)
3)depending on brand or model their is a damper which isnt opening to allow air flow into fresh food section
those are 3 possibilities all of which involve the air flow into the freshfood side to be blocked off
Jul 18, 2011 | Refrigerators
The freezer defrosted, and doesn't seem to be getting cold air. The refregerator appears to not getting cold air either.
replace the ptc overload relay on the compressor as it may sound like its running,but isnt,it merely unplugs and a new ptc plugs in place,it aids in compressor motor starting and running
Apr 10, 2011 | Refrigerators
Doesnt blow cold air can it be recharged
Hi, yes they can be recharged if that is the problem. You may have a bad compressor, condenser fan motor, a run capacitor, several things besides freon could be your problem. If you are able to get up on top and remove cover, turn it to low cooling and see if the small motor is running, and put your hand on the black pot/compressor to see if it is on. Let me know what you find.
Shastalaker7
Apr 16, 2010 | Dometic Rooftop RV Air Conditioner
I have U-line Model #75RB-00 Refrigerator, the motor does not run and no cold air, light does work
If your motor and compressor isnt running then replace the control. If the compressor tries to run but kicks out then you need to replace the fan. You can always bypass the thermostat to check everything before you guess at it.
Oct 01, 2009 | U-Line ?chelon 2175RB-00
Ac wont blow 2001 pontiac aztec
Are you saying the blower motor isnt working? Does the heat blow? If it doesnt replace the blower motor. If car isnt making cold air you can charge it yourself or go to auto zone the should do it for you. Check ac belt.
Sep 30, 2009 | 2001 Pontiac Aztek
High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Oct 26, 2008 | Heating & Cooling
Heating & Cooling Logo
52 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
