Question about Amana ARGS7650SS Gas Kitchen Range
Setting time and adusting display
We dont know how to set the time or adjust clock on the led display
Hi, Press on the word clock then hit your hour and minutes to set your time. Hope this helps.
Posted on Mar 25, 2009
Uhm How do you set the time ?? i have the clock up but i dont know how to set the time to what time it is !!!
1 Select Clock Adjustment Mode
Push The Control Knob Towards {FM} or {AM}.
select the "CLCK" display.
2 Enter Clock Adjustment Mode
Press the Control Knob For at least a second
The CLCK display blinks.
3Adjust the hours
Push The control knob Towards {FM} or {AM}.
Adjust the Minutes
Push the control knob towards {<<} or {>>}
4 Exit Clock Adjustment Mode
Press the {Menu} button.
Dec 26, 2010 | Kenwood KDC-135 CD Player
How to set time on Pioneer DEH-2290UB
1. Press SRC/OFF and hold until the unit turns off.
2. Press M.C. and hold until CLOCK SET appears in the display.
3. Turn M.C. to select the inital setting.
After selecting, perform the following procedures to set the intial setting.
CLOCK SET:
1. Press M.C. to display the setting mode.
2. Press M.C. to select the segment of the clock display you wish to set.
Hour-Minute
As you select segments of the clock display, the selected segment flashes.
3. Turn M.C. to adjust the clock.
Jun 03, 2010 | Pioneer Car Audio & Video
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
Set the clock on a clarion cd player?
Setting the Clock
1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
3) Select left or right to adjust the time using the a-selector
~Adjusting minutes
Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
~Adjusting hours
Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
*The clock only displays time in a 12-hour format.
There is no way to toggle the clock to a 24-hour format.
4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
Note:
*The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
Dec 08, 2009 | Alpine Car Audio & Video
I need to change the time on it.
You can try the following steps
Setting the clock
1 Press and hold SEL (select) for more
than 2 seconds.
“DEMO,” “CLOCK H,” “CLOCK M,” “DIMMER,”
or “AMP GAIN” appears on the display.
2 Set the hour.
1 Select “CLOCK H” (hour) if not shown on
the display.
2 Adjust the hour.
1 2
3 Set the minute.
1 Select “CLOCK M” (minute).
2 Adjust the minute.
1 2
4 Finish the setting.
To check the current clock time or change the
display mode
Press DISP (display) repeatedly.
Each time you press the button, the
display changes as follows:
• During tuner operation:
• During CD operation:
• During power off:
The power turns on and the clock time is
shown for 5 seconds, then the power turns off.
Thanks for using Fixya
Proton
Jul 27, 2009 | JVC KD-G200 CD Player
Cant change clock setting of pioneer deh 4050UB
I dont know what deck you have but you can try this. Turn off the deck by holding the source butten then hold the function butten you will be able to turn on and off the warn for the alarm along with the clock.
Mar 24, 2009 | Car Audio & Video
Alarm clock came with chinese instructions manual,I need English
1.slide "return to time"to off, slide "backlight" to on
2.each press of the mode button goes through "time, temperature, year, month(M looks like an H) and day(D), alarm1, "2, "3, , Birthday Celebration, countdown/stopwatch"
3. when on the category u want to change, press and hold set button for 3 secs, adjust with up and down and the hit set when done with each adjustment
Buttons on the bottom in order from left to right are(buttons on the top part of the clock bottom when turned on its side) mode, set, up, down
Jan 09, 2009 | Emerson Smartset Clock Radio
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
for more than 2 seconds.
The hour digits start flashing on the
display.
2 Press 4 or ¢ to adjust
the hour, then press
PROGRAM/SET.
The minute digits start flashing on the
display.
3 Press 4 or ¢ to adjust
the minute, then press
PROGRAM/SET.
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
Press DISPLAY.
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
Amana ARGS7650SS Gas Kitchen Range Logo
138 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
