Konka KDL32MS611A LED TV takes 5 seconds to change chanels. A box in top right appears and shows DTV then Dolby then 1080 before the channel actually changes. Can this be adjusted or sped up?n
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
SOURCE: Black rectangle box in lower middle of screen
Try turning off Closed Caption.
Posted on Jun 05, 2009
SOURCE: I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Posted on Jun 26, 2009
  • 136 Answers
SOURCE: lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Posted on Aug 08, 2009
dave1645
  • 834 Answers
SOURCE: chanels missing on freeview
rerun setup and they should be back
Posted on Dec 01, 2009
I have a vizio 470-a0 that is dark and the back light blinks every 5 seconds
The front LED light that shows whether the TV is on or off will flash so many ... press and hold the power button for 5 seconds upon plugging the TV in. ... The flashing code I got meant the power supply was bad.
Feb 08, 2016 | VIZIO, INC. E470-A0 47" 1080p LED-LCD TV -...
My tv is turning off itself after a few seconds and I can't change the channels. This problem starts when I open the google and search the movie tube. How can I fix this?
Hi
first you do factory setting because all data become normal then try again if problem remove then ok if still second update the software if remove then ok but still at last you should change the system board
Feb 19, 2015 | Sony BRAVIA KDL-48W600B 48 1080p LED-LCD...
How do I tune a tv to sky channel
Turn on sky box, select a menu so you have a steady output.
Easy way is a scart lead (no tuning required) choose "av1" or whatever your plugged in to.
If just using ariel lead, pick a channel on tv for example no 6 and tune that to frequency 68.
If your tv does'nt use these numbers then scan until it comes through
Jul 31, 2014 | Samsung T27B550 68.6 cm 27" 1080p LED-LCD...
How do i get chanel 5 and other digital chanels on my polaroid tv model no is T L U 01941W
choose input and then dtv and then a new search for your channels of course you need a antenna if the channels are free to air.
Nov 08, 2009 | Televison & Video
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Question regarding my Apex PF2720 TV: One channel
check your close captioning settings make sure they are off you probably are accessing an unused cc chanel
Apr 14, 2009 | Apex Digital PF2720 27" TV
How to tune my digital chanels in my bush lcd tv
Dec 19, 2008 | Televison & Video
No chanel higher than 13
If your set is cable ready, it should go up to channel 150 without a cable box. Check the settings to see if it is in cable mode and rescan the channels.
Nov 30, 2008 | Konka K1390U 13" TV
Tivo not working correctly
Cable chanels an dtv chanels are not the same
Oct 28, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Electro Med Services...
