My one 4 all is a tiny remote with no numbers to press for accessing code ..can anyone tell me how to use it
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Try onefarall.co.uk then go to there online help and enter ure model number it may be inside the battery housing without a model number i cannot help regards andyb
Posted on Apr 18, 2013
Can anyone tell me how to unlock the region code for an LG HT953TV DVD Player?
Power on.
Open tray.
Push the info on remote once (with supplied remote). You will see numbers.
Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
Power off.
Power on.
Jan 19, 2013 | Televison & Video
Retreving calls from another phone uaing my code does not work any longer. I would like to reset the code. Please give instructions. Thank You,
Changing the Remote Access Code The Remote Access Code is preset to 500. You can change the Remote Access Code to any three-digit number from 500-999. DO NOT pick the same number as that assigned to the Priority Calling Code. 1 Press g. The Message Window displays CH. 2 Hold down c for at least two seconds. The system announces "First digit." 3 Press / or ? to change the digit. 4 When the Message Window displays the desired first digit, press c. The system announces "Second digit." 5 Press / or ? to change the digit. 6 When the Message Window displays the desired second digit, press c. The system announces "Third digit." 7 Press / or ? to change the digit. 8 When the Message Window displays the desired third digit, press c. The system announces the new Remote Access Code.
Aug 26, 2011 | AT&T 1725 Answering Machine
Have a jumbo remote with no code search button also only programs 3 devices tv'vcr&dvd
I had the same problem Johny. Everybody wants to tell you how to program the one with the CODE SEARCH button. Here\'s how to do the one without. Press and hold the item button you wish to program (TV, DVD etc anyone of them can be used for anything) until the LED lights and stays on. Turn the item on manually and point the remote at it and push the power button. When the gadget turns itself off, immediately press the item button again. You can recall the code by pushing the item button until the light turns on again and then press DISP. Now push the number buttons (random is OK). As you hit the correct number of the code, the LED will flash until the four digit code is entered then the LED will go off. You may wish to try for more codes as some function better than others that just simply "work".
Jul 02, 2011 | Innovage Jumbo Remote Control
How to know what your access code is to retrieve messages away from home
A remote code must be entered when
operating the answering system remotely.
This code prevents unauthorized parties
from listening to your messages remotely.
Store any 2-digit number (00–99). The
default setting is “11”.
1 Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Set answering” by pressing
4 Scroll to “Remote code” by pressing
5 Select the desired remote code by
entering a 2-digit number (00–99).
6 Press {Save}, then press {OFF}.
Note:
LTo confirm the remote code, repeat
steps 1 to 4. Press {OFF} when finished
Dec 22, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
I lost my Universal remote manual for INTERTRONIC RC Pro. Can anyone please help me? I have a Roadstar telvision. Thanx please
Can you please give me the make and model no. of your universal remote so that i can let you know if there are any manuals available.
May 16, 2009 | Philips 483521917703 Remote Control
Need to unlock tf-dvd7008
Step 1- open the DVD tray
Step 2- Press the "MENU" button on the remote control
Step 3- Press" 8888"
Step 4- Press the " DISPLAY" button
Step 5- Select your region. I would suggest enter " 0", this will make it a all region player.
Step 6- Press the " SETUP button to exit.
Mar 31, 2009 | Coby TF-DVD7006
Remote control code for Emerson LC200EM8
Have you tried the searching for your code option on the 15-2147?
for example, turn on your Emerson LC200EM8( press the appropriate key on your remote, if this is a TV.#1.press the tv key on your remote)..#2.Press and hold the little 'p' key till the LED lite,on the remote, blinks twice..#3..then enter 9 9 1.(the led should blink twice).#4.Aim and..Press the Power off on the remote....(the remote will start sending IR codes from its library to the selected device, starting with the most popular.)#5..If the TV responds go to step 6..if not, press the CH+ button, until it does...step #6 when device responds, to lock in the code, press 'p' once, the LED blinks twice.
Once you have your number locked in,,,you can get the remote to tell you what sequence the code is in by #1Press the appropriate key on the remote.(i.e, TV press the TV key ....Dvd player or VCR, then press that key). (Note: make sure you are aiming the remote at the device so the IR(infrared) enters the device.) Step #2 Press and hold the 'p' key(upper right corner of controller) until LED blinks twice, then release....Step #3 enter the code 9 9 0 ..the LED lite blinks twice. ..Step#4 to get the first number of the code press th e number 1 on the controller...the LED will blink the once for 1 //twice for 2...three times for3...etc...write down how many times the LED blinks(if it doesnt blink the first number of the code is 0) Repeat step #4 to get the remaining numbers, i.e. for the second mumber of the code enter 2...third number enter 3...till you have all four numbers.( when done you can press a different device key to get you off... then press the right device key for your device to operate it remotely. Hope this helps
Aug 31, 2008 | Radio Shack (15-2147) Remote Control
Lost code
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Dec 27, 2007 | Kenwood KDC-MP235 CD Player
ACCESS/SECURITY CODE
Type 1
Type 2
Type 3
Nov 10, 2007 | Kenwood DPX-5010 CD / Cassette Player
Code for universal remote
This must be a duplicate post. And because I'm not sure which one you'll check I'll just post the answer here too... Diamond vision is a little pickey with handing out their code access. And Rogers doesn't have a whole lot about accessing components like DVD players. But try this: 1. Turn on DVD player 2. Press the AUX button at the top of the remote 3. Press and hold the SETUP button until the LED light blinks twice. 4. Press 9-1-1 in sequence, the LED will blink twice again. 5.Aim the remote at the DVD player and slowly alternate pressing POWER and AUX. Stop when DVD turns off. 6. Press SETUP to lock the code in memory. It may take several minutes of alternating between POWER and AUX to find the appropriate code - be patient... If after ten minutes you haven't got it try programming it as a VCR - steps 1 through 6 above and substitute VCR for AUX.. Good Luck Bill
Jun 10, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
