Question about MSI : 661FM-L P4 SIS661FX FSB800 Motherboard (MOT34)
My computer is automatically restart within 5-10 minute. without any warning?
  • MSI Master
  • 5,660 Answers
Http://www.msi.com/product/mb/661FM---661FM-L.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130440R
Is the computer dirty inside?
Do NOT reach inside your computer case, until after following Anti-Static Procedures.
Then take a look at the capacitors on the motherboard.
(Radial Aluminum Electrolytic Capacitors)
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://www.youtube.com/watch?v=KN6_-8fYHo0
Starts at 0:04
http://www.youtube.com/watch?v=YCSNWi3UHf4
Post back in a Comment.
We'll start here............
Regards,
joecoolvette
Posted on Apr 18, 2013
Engine stops without warning
Sounds like a sensor cutting out, take to auto electrician to get chkd. also get chkd the coil and the solinoid as these can do the same thing as they heat up.
Aug 26, 2012 | 2000 Honda Accord
Startup gives the following warning: a cooling fan problem is detected..
Replace the cooling fan
If you do not the computer gets hot within minutes and will shut down automaticly
Feb 26, 2011 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
My computer is restart automatically when i am on my work
This issue could be caused by any of the below possibilities.
  1. Software issue or error.
  2. Hardware issue or error.
  3. Heat related issue.
  4. Computer virus.
  5. Issue with operating system.
Answer:Software issue or error
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode. Additional information and help with getting into Safe Mode can be found on document CHSAFE.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
  1. From the desktop right-click on My Computer.
  2. Click the Properties option.
  3. In the System Properties window click the Advanced tab.
  4. In Advanced click the Settings button under Startup and Recovery.
  5. In the Startup and Recovery window uncheck the Automatically restart check box.
  6. Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors. Additional information about Device Manager can be found on our Device Manager page.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers. Additional information and help with computer drivers can be found on our drivers page.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer. Additional information about testing computers memory can be found on document CH000708.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date. Additional information about checking this can be found in document CH000533.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot, additional information about how hot your CPU should be running can be found on document CH000687.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
  1. Reboot the computer and enter CMOS setup as the computer is booting. If you are not familiar with how to enter CMOS please read through document CH000192.
  2. After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Jun 13, 2010 | Microsoft Windows XP Professional for PC
PC restarts automatically without error message
Sounds like you may have a virus. There are many good free online scanners. For instance try Trendmicro's housecall or Panda online scanner or the one from Symantec.
A great virus program is Antivir. There is a free edition.
Let us know if you need more help.
Oct 13, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
My computer reboots without warning while playing online videos or browsing the net. First it happens after working fine for some time and then it starts happening frequently. I have Windows XP media...
as my knowledge if the computer restarting by themselves always there are some error occured in this one area possibility :
1. error in software
2. error in hardware
3. error by virus infected
4. operating system issue
BUT :).. if u get this trouble after take some advennture in networld/network.. i suggest u computer ar sugessted with "blaster virus" the virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted. so the best way is update your security first
that is the first step
the second :i suggest u to run your computer in safe mode wait for several minutes if not reboot while running safe mode follow this step :
  6. Click Ok.
if still rebooting in safe mode there the issue is likely not software related but something else
the third :hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
  2. After you have loaded the computer in CMOS setup let the com sit
hope u luck
Sep 27, 2009 | Office Equipment & Supplies
When i turn my laptop on it wont load the toshiba screen
in the cmos setting load default and save it. restart the computer
Aug 13, 2009 | Computers & Internet
Computer crash and restart
Windows restarts without warning
Cause:
Heat related issue.
Computer virus.
Answer:
Click Ok.
Computer virus
Heat related issue
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
Jan 28, 2009 | Computers & Internet
JEEP CUTS OFF
have it checked for cods anyway...it may have a cam or crank sensor going bad
Dec 23, 2008 | 1999 Jeep Cherokee
Pc restarts automatically and unexpectedly
Good Evening Sunnyseber :
Hope that you are wellJ
You did not indicate the type of Operating System.
This document pertains to HP and Compaq computers with Windows Vista. If Windows Vista suddenly starts without warning, or restarts when you try to shut it down, it may be because your operating system is set to automatically restart when certain system errors occur. This feature of the Windows Vista operating system can be disabled. Use the information below to disable the Automatically Restart option. NOTE: In addition to the steps in this article, updating video card drivers is known to resolve many of the problems that can cause the computer to restart. Step 1: Disabling Automatically restart option to view error messages You can prevent the computer from restarting by turning off the Automatically Restart option:
  1. Click Start c00971562.gif .
  2. Right-click Computer , and click Properties
  3. Click Advanced system settings .
  4. Click the Advanced tab and select Settings in the Startup and Recovery section.
  5. Remove the check mark next to Automatically restart under System Failure .
  6. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
  7. Restart the computer. NOTE: The computer will no longer restart automatically when a problem occurs. Instead a blue screen appears with more useful information. You can now search for a resolution using the text from the error.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Sep 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Self diagnostic will complete automatically in 10 minutes
Problem for Brother MFC-7420 All-In-One Laser Printer Self diagnostic will complete automatically in 10 minutes
Aug 01, 2007 | Brother MFC 7420 All-In-One Laser Printer
MSI : 661FM-L P4 SIS661FX FSB800 Motherboard (MOT34) Logo
29 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
