Question about Norelco Health & Beauty
Phillips Jet Stream System not cleaning - Norelco Health & Beauty
Water is coming through the tray but there is a buzzing sound & there is not much water. Could there be a blockage with the jet stream feed into the drum of our Zanussi Jet stream 1400 ?
more than likely, the buzzing sound is probably the circ pump struggling. this is very common. first check filter is clear. if it is there is a hose from the circ pump to the top of the tub or to the door seal, make sure that isn't blocked. don't worry ab there not being much water in the machine, these machines don't use much.
Sep 01, 2016 | Zanussi Washing Machines
Where can I buy just the Phillips Norelco jet clean system?
There are several types of these. You will need to know the model number of your shaver to select the correct type. You will find them at shaveroutlet.com
http://shaveroutlet.com/catalogsearch/result/index/?cat=99&manufacturer=4&q=clean+and+charge&submit=
Jan 09, 2016 | Norelco Health & Beauty
I have a Jet Clean System that knocked over and laid on its side for a week. The cleaning fluid must have leaked into the circuitry because it no longer works. What can be done to repair it?
Parts are not available for the jet clean system. You may be able to purchase a complete replacement from shaveroutlet.com depending on the model number of your shaver
Nov 18, 2014 | Health & Beauty
How to descale your morphy richards jet stream 42271 iron
you must read your owner manual section maintenance or troubleshooting , or get contact support from the factory, via chat or phone.
God bless you
Sep 23, 2012 | Morphy Richards Jet Stream 42271 Iron
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
Lost directions on how to use jet clean system. Do not know how to use it.
Visit this site below and enter your product number. If you don't have your product number or it doesn't appear, then type in "jet clean" then scroll down and click on personal care. You can then click on a jet clean model and then open the .pdf of the manual. The instructions should be similar. There is nothing to using it. Fill the reservoir with jet clean solution to the max line. Put the shaver in the cradle heads down and press the button on the front of the cleaning base. If it doesn't stay down and clean you may have another problem. If so, then search "Norelco Arcitec Electric Shaver with Jet Clean" on this site and you can find answers to your problems.
http://www.support.philips.com/support/sms_page.jsp?userLanguage=en&userCountry=us
Jun 09, 2010 | Norelco Arcitec Electric Shaver with Jet...
Engine will not run at steady speed, govenor continually fluctuates , This engine is a Kawasaki FC420V-ES10 on a John Deere Riding Tractor Model LX176. I tried the mixture adjustment needle valve no help.
On top of carb you will see a jet that is slotted,remove with screw driver and use a very thin wire to clean out hole in jet.Some had a black metal clamp holding it in place,remove that one by removing phillips screw,black clamp then use small pliers to pull jet out of top side of carb.If this does not work remove carb bowl and jetting in bottom-center of carb and clean jetting holes with a small copper wire.The mixture screw is for low speed air/fuel mix,this engine does not have a high speed fuel screw.Fixed jet.
Dec 11, 2009 | Garden
Morphy richards jet stream iron
We have a water filter and softened water. Our iron is clean and went after 2 months.
A Morphy Richards Jet Stream Elite pro.
It is just the steam generator that has gone.
May 27, 2008 | Irons
Health & Beauty Logo
67 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
