Question about M-Audio Oxygen 49 USB Midi Controller
Oxygen 49 won't turn on
I plugged the key board in and let it install then after i started using it with Reason 5 and it turned off and now it wont turn back on
How to fix loose usb on Axiom 49 keyboard
Wow...just loose or intermittent as well? Most of these jacks and connectors are directly soldered to the main circuit boards which could mean broken and/or intermittent connection. Check your warranty status but if expired...to resolder check for a local electronics repair shop to help as the disassembly and intricate work may be beyond many DIY fans.
Jul 30, 2014 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Make sure you follow the steps of the procedure below exactly. Connecting incorrectly can make data
send and receive impossible.
1.
Turn off the digital piano and then start up
your computer.
• Do not start up the music software on your computer
yet
3.
Turn on the digital piano.
• If this is the first time yo
u are connecting the digital
piano to your computer, the driver software required
to send and receive data will be installed on your
computer automatically.
4.
Start up your computer's music software.
5.
Configure the music software settings to
select one of the following as the MIDI device.
CASIO USB-MIDI
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Sustain pedal does not work
Yamaha FC4 and FC5 sustain pedals are normally closed, sorry Fred. Roland is opposite. I suspect the P120 just needs to be reinitialized. Hold down top white key (C) while turning on power. Wait 3 seconds and then release white key. Should now be reset to factory spec. Always plug the pedal in before you turn it on. If it still doesn't work check it with a meter.
Mar 17, 2012 | Yamaha CP300 Stage Digital Piano...
I can't get my Behringer XENYX X1222 USB to control any of the faders within Sonar X1 Producer.
It may require the driver to be installed for the Behringer, or re-installed.
Go into the settings section of Sonar and if you can "De-select" M-audio as the default controler, or you may need to go through the preferences of M-Audio to find it.
To me it sounds like a driver is missing.
Jan 30, 2012 | Music
My P85 simply won't turn on. I have tried two different adaptors. Neither work yet they are functioning with other keys. Please help. I have a gig on Sunday
What adapters have you tried? The P85 REQUIRES a 12 VAC adapter, NOT the common DC type and it needs a 1.5 amp (1500 ma) type adapter. If you connected a DC adapter it will NOT do damage, the unit just won't work. You can find adpaters on Ebay or Google search.
Aug 26, 2011 | Yamaha P85 88Key Portable Digital Piano
I have a Casio Privia PX-130 and I tried to turn it on and it wouldn't turn on. I have noticed lately that when I would be playing a song that when I pressed a certain key that it would make this...
Test the adapter with a meter... Most probable cause is a bad power connector. Often the solder at the input power connector breaks loose is only problem. If you are not electronically adept, best to take it to a shop.
Jun 27, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
I cant get my knobs or sliders on my oxygen 49 controller working keys, octave and mode and pitch work fine, its just the sliders and knobs
Here is a link that might help:http://www.m-audio.com/index.php?do=products.directlink If your DAW isn't supported it might have a learn function that might help. Make sure you download the latest update.
Oct 18, 2010 | M-Audio Oxygen 49 USB Midi Controller
My oxygen 49 3rd generation (m-audio) midi keyboard just stopped working for me. Ive tried changing the usb lead, and I've tried it on a different computer, and it still doesn't work. I have a macbook pro,...
If the keyboard is lighting up, there is a 90% chance the problem is in the software in your MAC.
Hint: Software "breaks" easier than the hardware !!!
Re-install your software as a first step.
Sep 12, 2010 | M-Audio Oxygen 49 USB Midi Controller
CASIO CTK-800 turns on but no keys work, and then the power key will not turn it off. I have tried all of the trouble shooting solutions, i have tried different dc adapters, and nothing works. None of the...
That doesn't sound good. It sounds as if the processor is locking up and that might only be fixed by replacing the main board. Sometimes this happens if a unit gets fried by static electricity.
But before giving up, I would open up the unit and check for loose cables and connectors internally. If there are chips (IC's) that are socketed on circuit boards, push them down firmly. Things may start working again.
Apr 16, 2009 | Music
M-Audio Oxygen 49 USB Midi Controller Logo
137 people viewed this question
Top M-Audio Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Electro Med Services...
Are you a M-Audio Music Expert? Answer questions, earn points and help others
