Question about Samsung SF-3200 Fax
Just changed the ink cartridge and does not print
I have just changed the ink cartridge and dont get either fax or copier to print.Any suggestions
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
If it was working before you changed the cart make sure you removed any sealing tape on the new one. If you have then you likely have a bad cart.
Posted on Mar 14, 2009
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I am receiving an error in panasonic fax machine KX-FLB802 CHANGE SUPPLIES & CARTRIDGE LOW REPLACE SOON kindly tell me solution for this error or how to factory reset panasonic KX-FLB802 THANKS
Your printer is signalling that it is out of ink and that you should put a new ink cartridge in. Without a new ink cartridge it cannot print the pending faxes.
Mar 25, 2011 | Office Equipment & Supplies
Epson sx210 inkjet printer trying to change black ink cartridge but can't find how to get print head to move to correct position to remove cartridge.
If you're using Windows,
XP : Click Start, go to Control Panel > Printers and Faxes Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Vista : Click Start, go to Control Panel > Hardware and Sound > Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
7 : Click Start, go to Control Panel > Hardware and Sound > Devices and Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I need assistance on changing the ink cartridge. I can't get the machine to stop so that I can change it.
XP :Click Start, go to Control Panel > Printers and Faxes Right Click on your printer and click Printing Preferences. Click Maintenance tab, click Ink Cartridge Replacement. Follow the instructions. --- Vista : Click Start, go to Control Panel > Hardware and Sound > Printers Right Click on your printer and click Printing Preferences. Click Maintenance tab, click Ink Cartridge Replacement. Follow the instructions. --- 7 : Click Start, go to Control Panel > Hardware and Sound > Devices and Printers Right Click on your printer and click Printing Preferences. Click Maintenance tab, click Ink Cartridge Replacement. Follow the instructions.
Nov 21, 2010 | Epson Stylus Multifunction Inkjet Printer/...
When i recive fax or when i print it just it prints empty page
If the fax is acting like it is printing (print head moving back and fourth) then it sounds like the ink cartridge is clogged. Remove the cartridge and clean with cotton swab and rubbing alcohol. If this helps a little or not at all replace the ink cartridge. If it still prints blank, the print head could be the problem (this is where the ink cartridge goes). At this point it would be cheaper to replace the fax.
May 14, 2010 | HP J3680 Officejet All In One Printer
When we do a fax test, we get clear print; when we try to print documents nothing appears, altho it goes thru all the right sound motions
Sounds like your colour cartridge is empty. Fax test will pull from black only but documents sometimes use a combination of colours in order to print out black. I suggest checking your ink levels - instructions for windows;
Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low Check ink levels
Mar 05, 2010 | HP Officejet 5610 All-In-One InkJet...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Copier/Fax not printing
You have to change the setting from the control panel, go to Printer & Fax .. then properties.. open .. the settings and check if the background is selected or not then apply and then take a print.
Let me know if the problem persists we will investigate further.
Dont vote till you get the exact solution.
Oct 08, 2008 | HP OfficeJet J4580 All-In-One Laser...
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
In Use/Memory FAX after changing ink cartridge
I had the same problem - it would not print the faxes as the machine would not recognize the generic cartridge - I had to get the official Canon cartridge to get the faxes to print out of memory.
Mar 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Samsung SF-3200 Fax Logo
147 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
